high temp nylon hose?
Old Aug 2, 2012 | 02:45 PM
Pumpking.'s Avatar
Default high temp nylon hose?
wasnt sure where to put this. i assume more use push fittings in this section than any other subforums.
converted all my vac lines to nylon hose and metal push fittings. ran all the lines thru rubber hose and heat sheaths (sp?) anywhere near high temp areas, but noticed even lines away from high heat areas were soft and mushy, so i could only imagine my lines near the manifold are probably worse.
is there high temp nylon hose out there? links? what else you guys use? was thinking of going metal tubing/compression fittings if i cant source some nylon hose that withstands high heat.
Old Aug 2, 2012 | 03:02 PM
MrParks's Avatar
Default Re: high temp nylon hose?
I carry firestone dot high temp airlock line.
Old Aug 2, 2012 | 03:20 PM
luck4rmkc's Avatar
Could always use some of that reflective gold foil lookin tape to try to deflect some heat
Old Aug 2, 2012 | 09:28 PM
redboost10's Avatar
mcmaster has some high temp stuff
Tippyman
Sep 28, 2013 06:38 PM
greasemonkee
Welding / Fabrication
13
Jun 21, 2008 11:10 PM
bdubnyc
Mar 25, 2008 03:08 AM
Hondatuner88
Feb 13, 2008 06:56 PM
T-RO
Feb 24, 2004 08:44 PM
