HELP wheel hop!!!!!!!!
Old May 28, 2006 | 08:21 AM
boostd ls's Avatar
Default HELP wheel hop!!!!!!!!
i have a 98 civic hatch w/ lsvtec engine 189 hp and typer tranny 4.4 fd i have been running 1/8 mile but it wheel hops really bad i have installed lakewood traction bars no help still wheel hops like crazy i am running on street tires i have tried all different air pressures but no difference i have kyb struts and ractive coilovers that were on the car when i purchased it i am hoping some suspension will cure my problem but am unsure what would be best for a daily driven /weekend track car any info would be greatly appreciated thanks
Old May 28, 2006 | 02:20 PM
Humble Performance's Avatar
Default Re: HELP wheel hop!!!!!!!! (boostd ls)
What tire pressure have you been running ? Sounds like you have too much tire pressure. Just run a straight slick and you will get rid of the problem , just my .02 cents.
Old May 28, 2006 | 07:43 PM
boostd ls's Avatar
i started at 20 psi then 18 psi then 15psi then 12 psi no different wheel hop all the way threw first gear also what kinda 60ft should i see wit my horsepower in a ek hatch with slicks?????
Old May 29, 2006 | 05:57 PM
boostd ls's Avatar
any other opinions or advice
Old May 29, 2006 | 07:41 PM
Default Re: (boostd ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostd ls &raquo;</TD></TR><TR><TD CLASS="quote">i started at 20 psi then 18 psi then 15psi then 12 psi no different wheel hop all the way threw first gear also what kinda 60ft should i see wit my horsepower in a ek hatch with slicks?????</TD></TR></TABLE>
You should get 1.7 no problem , maybe even 1.6 if you heat the up properly and get a good launch.
BrowNKiD
Oct 13, 2008 09:20 PM
starcrossed010
Apr 18, 2007 12:54 AM
ShaDoWbOi
Jul 11, 2003 05:58 AM
elevatethis
Jun 2, 2003 09:22 AM
Kermit EK
Jan 30, 2003 09:27 AM
