traction issues any help???
Old Apr 16, 2007 | 03:21 PM
starcrossed010's Avatar
Default traction issues any help???
ok i have a ek hatch puttin down 264whp and 229tq. i am currently running bfg drag radials (205/50/15) which i believe are about 23 in tall. i run about 35 psi in them, but i am getting no traction at all in 1st or 2nd. i dont have much wheel hop so i am wondering if traction bars would be much of a help, and also, whats a decent tire pressure to drop to? i mean if you go to low with pressure youre only gonna be running on the sides anyways the center will belly upwards and not contact the road. anyone with any help??? the car is also a daily driver so i can run full slicks.. any help would be appreciated!!
Old Apr 17, 2007 | 06:07 AM
crxsir23's Avatar
Default Re: traction issues any help??? (starcrossed010)
my tire is a Little bigger i think their 225/50/15 i was running 8psi to 10psi had not one problem any thing higher than that i wound do nothing but spin if yours are like my the side wall well recoil
Old Apr 17, 2007 | 08:53 AM
anybody else have any opinions? traction bars a good idea or no??
Old Apr 17, 2007 | 08:54 AM
bummppppp anybody?
Old Apr 17, 2007 | 04:47 PM
tmac007's Avatar
Try Lower pressure around 10 psi.
At 35 psi those tires are going to give you a very small contact patch.
Old Apr 17, 2007 | 06:09 PM
Default Re: traction issues any help??? (tmac007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmac007 &raquo;</TD></TR><TR><TD CLASS="quote">Try Lower pressure around 10 psi.
At 35 psi those tires are going to give you a very small contact patch. </TD></TR></TABLE>
thanks i have thought about dropping but i wasnt sure how low i would want to go.. ill try 10 at the track this weekend. any other suggestions??
Old Apr 17, 2007 | 10:18 PM
eg_6sick's Avatar
drop the tire pressure and u will notice a difference
Old Apr 17, 2007 | 10:26 PM
crxsir23's Avatar
Default Re: traction issues any help??? (eg_6sick)
stiffen up the rear end
Old Apr 17, 2007 | 10:52 PM
IT'S ME DAVID's Avatar
NooB
Default Re: traction issues any help??? (crxsir23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsir23 &raquo;</TD></TR><TR><TD CLASS="quote">stiffen up the rear end</TD></TR></TABLE>
And yes traction bars will help out alot.
Old Apr 18, 2007 | 12:54 AM
H-T guy's Avatar
Default Re: traction issues any help??? (IT'S ME DAVID)
ya your tires are will not get any traction about 20psi i would try 12psi and work your way down from there.
traction bar does help, but work on getting a consistant 60'ft. before buying one.
JDMlyfestyle
Jun 25, 2004 11:21 AM
99lspwr
Oct 7, 2003 06:45 AM
3rdGteg
Mar 30, 2003 03:29 PM
itr-j
Sep 2, 2002 02:48 PM
