Help with MSD 2-step wiring
Old Oct 8, 2005 | 03:38 PM
gsrvx's Avatar
New User
Default Help with MSD 2-step wiring
Hey guys...I have a 6AL with 2 step module. It's being activated by a clutch switch. However I would like it to de-activate after the launch...when I shift thru gears...the 2step limit kicks in when I push in the clutch. I've been told something about a momentary switch. Can someone point me in the right direction?
Old Oct 8, 2005 | 04:04 PM
dome's Avatar
Default Re: Help with MSD 2-step wiring (gsrvx)
forget the clutch switch idea. i would put a button on the steering wheel. hold the button in on the line when your ready to go just let the button out. with the clutch switch your clutch has to be to the floor or close to it. i like to preload my clutch at the line so i dont break anything. 3/4 of the way out so in that case i would not be able to use it. plus the clutch switch will tend to ben on you. its junk
Old Oct 8, 2005 | 04:37 PM
Rage Cayman's Avatar
Install a toggle switch to cut it off after you launch.
Old Oct 8, 2005 | 05:34 PM
dome's Avatar
Default Re: Help with MSD 2-step wiring (turbocrx1.6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocrx1.6l &raquo;</TD></TR><TR><TD CLASS="quote">Install a toggle switch to cut it off after you launch.</TD></TR></TABLE>
no that is not how you want to do it. momentary switch is what you need.
Old Oct 9, 2005 | 11:21 AM
gsrvx's Avatar
New User
Default Re: Help with MSD 2-step wiring (dome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome &raquo;</TD></TR><TR><TD CLASS="quote">
no that is not how you want to do it. momentary switch is what you need.</TD></TR></TABLE>
Thanks for the replies guys. How do i go about wiring the momentary switch?
Old Oct 9, 2005 | 11:26 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrvx &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the replies guys. How do i go about wiring the momentary switch?</TD></TR></TABLE>
It will be very simple. Just a Positive, Accesory (the 2 step module), and a Ground. You can get a cheap momentary switch at any Radio shack or Parts STtore.
Phil
Old Oct 9, 2005 | 12:57 PM
dome's Avatar
Default Re: Help with MSD 2-step wiring (hondaguyef)
i got on with the cord to mount to the wheel 50 bucks plus shipping
cdust
Feb 15, 2018 05:34 PM
418whpturboD
Mar 19, 2008 05:10 PM
binarypunk
Sep 24, 2007 06:04 PM
SPOOLINmatt
Mar 7, 2005 09:43 PM
V-SPEC 1
Dec 24, 2003 11:23 PM
