3 step rev limiter switch
Old Dec 22, 2003 | 09:54 PM
V-SPEC 1's Avatar
Default 3 step rev limiter switch
Hey guys and gals, where can I purchase a good switch for my msd 3 step rev limiter at? I want the switch that would work nicely for the clutch activation. I know a lot of you use this type of switch where your clutch is. Any help would be appreciate. Thanks,
Vic
Old Dec 23, 2003 | 04:57 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: 3 step rev limiter switch (boostedb20vtec)
You dont need to purchase a switch for your clutch activation. I have the 3step module, and one of them is activated through the stock clutch switch. If you use this switch tho, you will no longer have to hold the clutch down when starting the car.
Old Dec 23, 2003 | 06:19 AM
DOHCarp's Avatar
I simply got a NOS systems micro switch and mounted it underneath my clutch pedal so I wouldn't have to get rid of the factory clutch switch. Also if my memory serves me correctly the factory switch is a ground type switch so if you use a relay you could have the relay send 12v to the three step. This would also enable you to keep the factory clutch switch working. I opted for the micro switch cus it was extremely easy and it cost 7.95.
Old Dec 23, 2003 | 03:20 PM
FULLTHROTTLE's Avatar
Default Re: 3 step rev limiter switch (DOHCarp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp &raquo;</TD></TR><TR><TD CLASS="quote">I simply got a NOS systems micro switch and mounted it underneath my clutch pedal so I wouldn't have to get rid of the factory clutch switch. Also if my memory serves me correctly the factory switch is a ground type switch so if you use a relay you could have the relay send 12v to the three step. This would also enable you to keep the factory clutch switch working. I opted for the micro switch cus it was extremely easy and it cost 7.95.</TD></TR></TABLE>
Yeah, what he said. Same setup here.
Old Dec 24, 2003 | 06:30 AM
V-SPEC 1's Avatar
Default Re: 3 step rev limiter switch (FULLTHROTTLE)
So, when you mounted the switch under the clutch pedal, did you have to make some kind of bracket or modify it or bolt it straight up.
Old Dec 24, 2003 | 06:35 AM
DOHCarp's Avatar
I picked up the mounting bracket for the NOS switch, it made mounting it simple.
P/N 15640NOS Micro-Switch and Bracket (this is the part number from NOS)
Old Dec 24, 2003 | 11:23 PM
V-SPEC 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp &raquo;</TD></TR><TR><TD CLASS="quote">I picked up the mounting bracket for the NOS switch, it made mounting it simple.
P/N 15640NOS Micro-Switch and Bracket (this is the part number from NOS)</TD></TR></TABLE>
I got the micro switch today, damn, it cost me $12.00
cdust
Feb 15, 2018 05:34 PM
josh352727
Aug 19, 2011 08:54 AM
SPOOLINmatt
Mar 7, 2005 09:43 PM
