having problems with my launch, need input.
Old Jul 24, 2004 | 05:20 PM
hbracer93's Avatar
Default having problems with my launch, need input.
i have an all motor ls/vtec pushing 195whp, and 136tq and i can't break a 2.2 60' times on street tires. i only got 2 runs, so i didn't get a lot of time to experiment. any advice you guys can give would be great
Old Jul 24, 2004 | 10:17 PM
SlowMotion's Avatar
Default Re: having problems with my launch, need input. (hbracer93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbracer93 &raquo;</TD></TR><TR><TD CLASS="quote">i have an all motor ls/vtec pushing 195whp, and 136tq and i can't break a 2.2 60' times on street tires. i only got 2 runs, so i didn't get a lot of time to experiment. any advice you guys can give would be great</TD></TR></TABLE>
What size and type of street tires are you using? Unless you want to purchase slicks, I would suggest BFG drag radials and low PSI. To find out exactly how low you will have to play arond w/PSI and see what works best with your setup. Plus whats your susp/alignment setup?
Old Jul 25, 2004 | 08:26 AM
CNSK's Avatar
How high are you reving? Try feathering out your clutch rather then dropping the clutch....
Old Jul 25, 2004 | 10:18 AM
hbracer93's Avatar
i have 15" brigestone potenzos, with stock shocks and h&r springs, i rev to 8500rmps...see i was using the gas alone and tring to control it that way, next time i go to the track i will try that
Old Jul 26, 2004 | 08:38 AM
CNSK's Avatar
Default Re: (hbracer93)
oh my goodness..8500?? you need slicks...potenza are not gonna hold......trying reving 3500-4000 and work on high or how low you need to set your rpm at....
Old Jul 29, 2004 | 07:54 AM
hbracer93's Avatar
sorry i must of mis understood the question off the line i launch at like 2500 to 3000rmps
Old Jul 29, 2004 | 08:52 AM
dohcter g's Avatar
Use the hand barke and let the car pull while the lights drop. When green drop the barke and feather the clutch. I ran 2.05 60 with street tires using this method. Also if you want to get good traction with street tires use VHT Track bite.
Old Jul 29, 2004 | 10:22 AM
CompressionFed's Avatar
Default Re: (dohcter g)
This is the method that I use also...pre-load the suspension, rev to 3500-4000, and slip the clutch.
I cut 2.0 60' on street tires.
Old Jul 29, 2004 | 03:10 PM
evilk's Avatar
hey wit street tire i launch at 5000 rpm and i hit a 13.2 on my ls/vtec
tapboyzlilj
Jul 3, 2007 12:19 PM
Pnoyej6
Jun 12, 2007 09:31 PM
jdm2teg
May 29, 2006 05:37 PM
Jockobo
Nov 8, 2002 05:57 AM
