to handcuff or not to handcuff
Old Jun 18, 2006 | 06:32 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default to handcuff or not to handcuff
with the power i am making, i am starting to get scared, especially with how high i am launching.
so far i am 540 +- whp, launching at 8200 (preloaded) and tranny is holding up.
should i handcuff? it is a street car BUT i just drive local, so 5th gear loss isnt the end of the world.
PROS AND CONS PLEASE!
t.i.a.
Old Jun 18, 2006 | 07:02 AM
DaveF's Avatar
Default Re: to handcuff or not to handcuff (boostedcivicsir)
handcuff / of story, you dont want to have to buy a new bellhousing and 4th gear or maybe more gears cause of the shafts riding against eachother. and maybe even have to buy a new clutch after all the oil in your trans get all over the clutch discs and glazed them over. the libertys gears cuff works great
http://www.libertysgears.com
Old Jun 18, 2006 | 07:11 AM
Mr. Badwrench
Default Re: to handcuff or not to handcuff (dturbocivic)
thanks dave. i was actually looking at the liberty piece.
Old Jun 18, 2006 | 09:10 AM
reaction360's Avatar
they're not badly priced either. I have also been thinkin about this as well. but I drive mainly freeway haha
Old Jun 19, 2006 | 11:06 AM
MIDnightblackDA's Avatar
its a must.. makes a big difference.. hit up Tom at Camp1320.com they got them for good pricing the liberty ones too.
Old Jun 19, 2006 | 11:44 AM
Danny_EJ's Avatar
I know it is off topic but what does this handcuff do? Ensure the tranny doesnt grenade ??
Old Jun 19, 2006 | 11:47 AM
Mr. Badwrench
Default Re: (Danny_EJ)
ties the counter and main together so they dont spread apart or force together. i thought it was to keep them from spreading.
but from what dave said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">handcuff / of story, you dont want to have to buy a new bellhousing and 4th gear or maybe more gears cause of the shafts riding against eachother. and maybe even have to buy a new clutch after all the oil in your trans get all over the clutch discs and glazed them over. the libertys gears cuff works great
http://www.libertysgears.com </TD></TR></TABLE>
it seems that they like to collide.
dave please clarify.
Old Jun 19, 2006 | 11:55 AM
Importracer_001's Avatar
Default Re: (boostedcivicsir)
Is there a handcuff for the early Bseries cable trannies too?
Old Jun 19, 2006 | 04:28 PM
JL's Avatar
JL
Default Re: to handcuff or not to handcuff (reaction360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">they're not badly priced either. I have also been thinkin about this as well. but I drive mainly freeway haha </TD></TR></TABLE>
haha.. just drive in the slow lane down I-5
Old Jun 19, 2006 | 05:40 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">ties the counter and main together so they dont spread apart or force together. i thought it was to keep them from spreading.
dave please clarify.</TD></TR></TABLE>
let me start this off with, "i am no engineeer by any means, so correct me if im wrong"
judging by the direction of the rotation/cut on the gears/location of the gear, the gears would indeed be "pulled together".... 4th gear would "pull" the counter and main shaft into eachother, as well as the ring/pinion being pulled into eachother throughout every gear, the highest amount of stress being placed on the "bellhousing" portion of the trans case in 4th gear(think of a long lever as opposed to a short lever) ..... think of it like this..... / &lt;-- thats your mainshaft, then we have, \ being your countershaft, then another \ and / being your ring gear and pinion gear respectivly, all of these gears trying to mesh properly @ god knows how many RPM's, a CAST aluminum case, so something has to "give" eventually.
so we have a / \ / \ "type pattern" all of these gears are going to try and "ride up" on eachother, which in turn will crack the case. the actuall gears (1-4) are trying to ride eachother (pull into eachother) through every gear, and the ring and pinion are also trying to ride eachother through everygear, both being "pulled" in opposite directions, 1st gear being the least likly to crack a case, because it is more "center" in the trans, and 4th being the worst case scenario(sp) because of the height of the gear compared to where the ring/pinion are located in the trans.
i dont know how complete/right/wrong..... of an explaination this is, ive had a few beeers tonight. so take it for what it is.... this is my interpratation of what happens to a transmission when it cracks case's...............
Old Jun 19, 2006 | 06:11 PM
SFWDcoupe's Avatar
Default Re: (dturbocivic)
how about BUCK02's cuff kit?
Old Jun 19, 2006 | 07:02 PM
redboost10's Avatar
Default Re: (SFWDcoupe)
ill put my vote in for buck02 cradle. very nice piece and customer service.
http://www.blmotorsports.com
Old Jun 19, 2006 | 07:59 PM
B18C1CYA's Avatar
from what I was told they push apart so the gears are not meshing all the way together and they just ride on the tips of the gears , cusing them to just strip off , I have had this happen once so far , I welded some braces to my trans case to make it stronger and so far so good , but if it takes a **** again it is getting the "HANDCUFF" cus it is a bad bitch lol
Old Jun 19, 2006 | 08:09 PM
FMUNK's Avatar
Default Re: to handcuff or not to handcuff (B18C1CYA)
I strongly recommend a liberty handcuff, if you do not mind losing 5th gear.
At some point they WILL start spreading, breaking gears and cases.
My Vote: Handcuff
We can sell you a Liberty Cuff or you can buy the Liberty Cuff from Buck02, I do not care, JUST BUY LIBERTY PRODUCTS!
Libertys Gears
If you ever go to a LG gearset, you will use the cuff you already have. So it is a part you would use as long as you had a B-series trans.
Old Jun 19, 2006 | 08:22 PM
DIRep972's Avatar
Smarter than you
Default Re: to handcuff or not to handcuff (FMUNK)
If anyone prefer's the Phantom Grip cradle I have a nice deal on one in my sig. Same one Chuck Sitsinger is using.
Old Jun 19, 2006 | 08:25 PM
Mr. Badwrench
thnaks for everything fellas. at the end of the season, it is getting liberty cuffs.
usdm_ED7
Transmission & Drivetrain
Aug 10, 2011 07:26 AM
new_climber
Feb 19, 2011 02:25 PM
SpoonCivicSir20
Oct 13, 2008 08:13 AM
4everVtec
Mar 9, 2007 12:23 AM
Snailed EF
16
Oct 17, 2006 03:23 PM
