GS-R shift points
Old Feb 25, 2003 | 01:56 PM
sleedawg's Avatar
Default GS-R shift points
Got a question for those running a stock GS-R tranny w. stock rev-limit. What revs are you getting when you shift from 1st to 2nd and 2nd to 3rd. From 8000 to xxxx rpms on upshifts? I'm trying to build a short gear tranny, and looking for info on GS-R shift points. Thanks!
-steve
Old Feb 26, 2003 | 06:29 AM
SergEK's Avatar
Default Re: GS-R shift points (sleedawg)
-steve
Shift points for most VTEC motors will be right before fuel cut....I know shiftin at 8000 on a B16/ITR tranny takes you down to highs 5K's 56-5800
A GSR should shift at/near fuel cut for best acceleration...
Old Feb 26, 2003 | 07:52 AM
sleedawg's Avatar
Default Re: GS-R shift points (SergEK)
SergEK... thanks for answering... what i'm specifically looking for is someone to go out in a GSR and shift at fuel cut and tell me what the revs drop to. I know the GS-R tranny has a smaller 2nd vs. the Civic SI/ITR trannies, so I wanna know how much more the revs drop in a GS-R compared to the Civic SI/ITR trannies as I want to close up the spacing between 2nd and 3rd for road racing.
Old Feb 26, 2003 | 07:57 PM
SergEK's Avatar
A few hundred rpm at most different....best thing to do would be to slap a 4.9 FD and call it good...unless you want a custom gear set at which point ATS should be your next stop...their web site is pretty informative when it comes to shift points and FD's
Old Feb 26, 2003 | 08:00 PM
sleedawg's Avatar
SergEK, thanks for the pointing of the ATS website. I've already spoke with them, and with Kaaz, and with King/Mugen about short gearbox. I am going with a completely new set of gears customized to my needs. As I said, the GS-R has a different second gear from the Civic Si/ITR and I'm trying to see how much difference having the second gear from the GSR and remove my SI. Anyways... I had someone go out in a GSR for me and give me the data I needed. Thanks!
GSR Hatch Ridin
Transmission & Drivetrain
Oct 14, 2011 01:53 PM
j_wod2000
Jul 27, 2005 07:10 PM
Red1.7DB
Jan 4, 2004 08:26 PM
sieger
Apr 4, 2003 10:45 PM
sleedawg
Feb 27, 2003 12:25 AM
