as good as it gets?
Old May 6, 2004 | 08:54 PM
91' LS-VTEC's Avatar
Default as good as it gets?
R/T ... .239
60'......1.998
330.....5.956
1/8......9.249
mph.....74.89
1000.....12.078
1/4.....14.515
mph...93.35
On BFG's 88'CRX with a B16A ,S1 tranny,h/i/e GUTTED!Vtec kicks in @ 4200RPM's ,shifting @ 8000rpm's
is this pretty much the best i can get out of this motor as it is?
Modified by 91' LS-VTEC at 1:32 PM 5/7/2004
Modified by 91' LS-VTEC at 1:49 PM 5/7/2004
Old May 6, 2004 | 09:35 PM
DragInteg's Avatar
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
Default Re: as good as it gets? (91' LS-VTEC)
Get a different tranny, 93 gsr trans.
Old May 7, 2004 | 12:51 PM
Default Re: as good as it gets? (DragInteg)
add a few things to my first post. tranny, when I shift. Someone lmk, is this is what I can expect out of my B16A for now. I'm working on a 2nd motor that will have alot done to it, but for now this is my set up... TIA.
Old May 7, 2004 | 03:56 PM
DIRep972's Avatar
Smarter than you
60ft looks awesome for radials. if you rev it higher you could probably get a better time out of it.
Old May 7, 2004 | 05:17 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragInteg &raquo;</TD></TR><TR><TD CLASS="quote">Get a different tranny, 93 gsr trans.</TD></TR></TABLE>
Why?
Other than better strength and reliability, the only gearing advantage it has is a slightly shorter first gear. The JDM S1 is just fine.
I think your 14.5 is probably about it. The 93 MPH seems a little low. Try to invest in some nice cams for more power.
EDIT: Here's a thought. My B16 seems to run best when vtec is set around 5000. Any less and it bogs. I hit a 14.3 with it at like 5100.
Modified by Mr. S at 7:07 PM 5/7/2004
Old May 8, 2004 | 08:39 AM
Default Re: as good as it gets? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote"> if you rev it higher you could probably get a better time out of it.</TD></TR></TABLE>
that funny you say that. I usally launch around 4,800-5,000rpm's. Well last night I launched @ 6,000 and my axcels said SNAP!. Befor that i got 1 run in at 14.7
Old May 8, 2004 | 09:54 AM
justinh595's Avatar
you are losing power with vtec hitting at 4200 rpms. put it back up to stock and run it again. i think it has more than that in it. a friend of mine last night at maple grove was running a 91 crx hf w/ b16 swap and couldn't pull better than a 14.8 on street tires while playing with his vtec point. i told him to put it back to stock and he ran his best of 14.6 on street tires with a 2.2 60ft. the only time you should play with vtec actuation is on a dyno so you can see its gains and losses.
Old May 8, 2004 | 10:32 AM
Default Re: as good as it gets? (justinh595)
sounds like a plan... Thats the 2nd thing rite now on my to-do list. 1st replace axcel
Old May 8, 2004 | 10:48 AM
Speedz's Avatar
one thing you guys are forgetting.. when he shifts at 8k, he probably drops down to 6000 rpm for the next gear.. he's not loosing any power when vtec kicks in at 4800.. the motor should have never dropped out of vtec.. unless he's spending too much time and his rpm dropping down to 5k.. then yeah.. but i doubt that.
he's got a great 60', and a good 1/8th mile ET.. mph is slightly down.. one of my buddy's here with a b16 crx usually runs 75mph in the 1/8th..
it seems as though its loosing some top end the 2nd half of the quarter... (slow shift?.. or maybe chirping the tires?)
Old May 8, 2004 | 12:37 PM
justinh595's Avatar
Default Re: as good as it gets? (Speedz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedz &raquo;</TD></TR><TR><TD CLASS="quote">one thing you guys are forgetting.. when he shifts at 8k, he probably drops down to 6000 rpm for the next gear.. he's not loosing any power when vtec kicks in at 4800.. the motor should have never dropped out of vtec.. unless he's spending too much time and his rpm dropping down to 5k.. then yeah.. but i doubt that.
depending on how hes launching his car it may fall out of vtec at the beginning in 1st gear. even if it were to not fall out of vtec and were to drop down to say 4300 or even 4600 hes still gonna lose power because because it shouldn't hit vtec until 4900 or 5000.
Old May 8, 2004 | 01:36 PM
DIRep972's Avatar
Smarter than you
that sucks u broke the axles. I wasn't saying u should rev higher on the luanch but rev higher at the end of each gear. usually b16's are still making good power @ 8k so when u go to a higher gear u r missing out on some acceleration still.. I think revving it to 8500 could get u another 1/10th or so.. keep the luanch how it was when u hit the 1.9
Old May 8, 2004 | 02:08 PM
I'm going to keep my luanching under 6000 for a wile. All I want to do now is replace the axcel and get back out to the track. I'm going to get my vtec set in around 5000 and start shifting at 8200. Thanx for all the input. Keep it comming.
Old May 10, 2004 | 05:26 AM
Speedz's Avatar
hmm.. i guess i didnt take into consideration where he launched at.. i usually launch at 6k or 6.5k.. i allow my tires to spin and let the drag radials do their job. i never bog and drop out of vtec doing this.
b20beast83
Sep 12, 2008 05:55 PM
ITRiWISH
12
Aug 14, 2007 08:18 PM
1SOL2NV
Jul 6, 2004 02:20 PM
MattGSR
Feb 23, 2004 05:24 AM
SupaFly_Honda
May 2, 2003 09:45 AM
