fuel cell question
Old Feb 1, 2011 | 11:05 AM
061000rr's Avatar
Default fuel cell question
for those running fuel cells (example, nrg, fcs) how do you go about knowing how much fuel is in it and how much to put in it without overflowing it?
Old Feb 1, 2011 | 11:12 AM
xenocron's Avatar
Default Re: fuel cell question
I believe for the NRG its designed to be filled every round (and you corner scale the car with a full tank)
The FCS I believe has a provision to use the stock sending unit, or one they provide.
Old Feb 1, 2011 | 11:45 AM
061000rr's Avatar
i was wandering with the fcs if you could add a simple one wire gm sending unit like most boat tanks have. you just need about 4 inch's on top to have enough room to drill the hole and weld a flange to bolt the unit to
Old Feb 1, 2011 | 12:04 PM
onefstek's Avatar
The way I made mine is to fit the stock sending unit to the top. CNC'd a mounting plate so I weld it on top of the tank and the oem sending unit bolts on to the plate.
Stefan
Old Feb 1, 2011 | 12:15 PM
061000rr's Avatar
does anyone no if the fcs fuel cell has enough room on top to weld in a sending unit?
Old Feb 1, 2011 | 02:24 PM
jdm inc's Avatar
to get your best answer i would contact jason park or give fcs a call. http://www.fcsfab.com/
like xenoncron said I believe u can get one install in the fcs tank,
Old Feb 1, 2011 | 03:05 PM
redboost10's Avatar
I believe msd makes an aftermarket fuel sending unit that isn't so bulky as oem.
Old May 3, 2011 | 05:36 PM
MrParks's Avatar
our sender units work specifically with the oem cluster. and is about 1/4 tall. no cutting no drilling.
NACvicSi
Oct 29, 2013 04:23 PM
CoolRedXylophone
Feb 25, 2006 07:19 PM
dohced
Feb 25, 2004 07:43 PM
275Performance
Jan 19, 2004 05:36 AM
InfamousRS
Dec 20, 2002 09:13 AM
