Front end dropping
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1junkycivic »</TD></TR><TR><TD CLASS="quote">Why would frontend drop between shifts first to second gear?Yes full throttle shifting is done.</TD></TR></TABLE>
If your serious about fixing this, talk to rota92.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">::flamesuit on::
I can't see how an off the shelf kit will be the best for all of these individual setups that are out there. Plus I think anything over an 850lb spring is too much, the rest should be done with the proper valving. Ed at progress will build you a setup to reflect your car, for example my car never fell on it's face while shifting once I started flat footing it. The car should transfer a bit (lower spring rate) but the valving should let it stay there and not try to level the car back to a neutral state.
Also, keep in mind the off the shelf stuff was designed around a stock car with the weight distribution of the car greatly different than that of a stock car. Some guys have hundreds of pounds more in the front of the car, and hundreds less in the back half (okay maybe 100 tops as there isn't much there but you get the point) But this all plays a pivotal role in how the chassis behaves.</TD></TR></TABLE>Thanks for info.More $$$$$ :
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGTUNA »</TD></TR><TR><TD CLASS="quote">Torsion Bar= Honda Tech's new traction snake oil. OBX is in over drive working on them.</TD></TR></TABLE>
can u explain this a lil more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm inc »</TD></TR><TR><TD CLASS="quote">
can u explain this a lil more </TD></TR></TABLE>
The obx part was a joke about knock offs, and the rest is well Honda-Tech every time someone goes fast that has a odd part on their car, the odd part get's 100 percent of the credit. Then everyone gets in fury buying the odd or new part.
The obx part was a joke about knock offs, and the rest is well Honda-Tech every time someone goes fast that has a odd part on their car, the odd part get's 100 percent of the credit. Then everyone gets in fury buying the odd or new part. </TD></TR></TABLE>
lol
lol
i meant the torsion bars stuff and how it works cuz it was mentioned in another thread and was wondering how it works on a drag car thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">It's pretty much the same as a normal traction bar, but it's attached to a torsion bar in front or back of the motor and helps to adjust preload and such in theory.
I haven't seen enough positive reinforcement, so I'm saving the time and running a normal setup. But I think I will have provisions for mounting them in there as a just in case sort of deal.</TD></TR></TABLE>
thanks ryan. cant wait to see your hot rod GL with the build.
on a rwd a torsion bar uses the weight distribution of launching and rotation of the rear end to slam the rear tires in the ground. a less severe setup, or less violent setup is a set of ladder bars. with a light car not making much power a very very short set of torsion bars is the way to go. i know this means nothing to this forum due to we are all mostly fwd's, but we have played and played with torsion and ladder bar setups on our superstock, along with shock adjustments.
there was a guy on here that incorporated a ladder bar system into his fwd civic.
My 1970 Duster had torsion bars on the front suspension. When I'd launch the car the whole car raised up 2-3" to plant the rear tires.
The bars ran from the lower control arms back to a someplace under the floor pan under my feet.
Has anybody thought about this type lay out?
Sorry to hi jack the thread.
didnt practically all dodge/mopar cars have front torsion bars in the 60's and 70's. some guys pick those chassis to run in stock/superstock just for this reason. many have their arguements about this being beneficial. yes they run back and connect to the frame i believe
its always fun building pair of equal length stainless steel headers on a mopar with front torsion bars...especially if they want tri-y's
most of which parts and suspension have mixed results. only the few will know how things work together in unison. having all the trick suspension parts dont do **** if not used and setup properly. torsion bars are not anything new. actually there pretty ancient.
lets see if the pat pending jj suspension stuff comes out. love to see what that can do for 330s
what if an NA car is lifting the front-end right off the start and putting much flex on the wheelie bar ... what would you rota92 suggest to keep??
...26x8.5 fronts
to the OP, sorry to jac' just heard that rota92 was the man to talk too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si »</TD></TR><TR><TD CLASS="quote">If your serious about fixing this, talk to rota92.</TD></TR></TABLE>
...26x8.5 fronts
