Front brake setups
Old Feb 5, 2012 | 11:38 AM
slowboy90's Avatar
Default Front brake setups
I Have a kens custom setup on just front brakes im wonder what rotors, pads, and calipers people are running to stop at 150+mph
Old Feb 5, 2012 | 12:50 PM
Divers's Avatar
Default Re: Front brake setups
Ken's custom what? What is from kens custom if you have no rotors, no pads, and no calipers? booster delete?
Old Feb 5, 2012 | 12:57 PM
89efhatchy's Avatar
Thats what he means.
Old Feb 5, 2012 | 01:01 PM
utahturbosohc's Avatar
Stock cx brakes here. Stops fine from +145. Stock gsr brakes on CG Racings car, stopped fine from +160
FlewByU352's Avatar
We should make this a "post your drag racing brake setups" pictures needed for us with simple minds :D InB4 parachute...
Old Feb 5, 2012 | 01:15 PM
sanman000719's Avatar
stock ef brakes stop me at 146 just fine as well
Old Feb 5, 2012 | 01:41 PM
Jdmsolutions's Avatar
this gives me hope for my stock dx brakes on my ef for this season!
Old Feb 5, 2012 | 01:43 PM
yah man stock everything, and it does just fine for me
i do not pull it out of gear in the end, and i pump the brakes as well
i am going to steel braded lines this year, but ill also have a shoot lol
Old Feb 5, 2012 | 07:08 PM
Zer0_SpeedWorks's Avatar
Kkc booster delete
GSR brakes 10.3
Goodridge lines
Akibono pads
Old Feb 5, 2012 | 07:15 PM
Divers's Avatar
Stock cx calipers on ex rotors. EBC redstuff pads. Front brakes only. 170+ no problem.
You don't take it out of gear?! Just let it hang?! That'll cost you a motor some day.
Old Feb 5, 2012 | 07:19 PM
i do apply the clutch lol i didnt mean for it to sound like i allow the engine to help slow it down
Old Feb 5, 2012 | 07:45 PM
theidealone's Avatar
I put mine in 5th and let is compression brake. No issues with that that I know of. I did it because I dont have an electric water pump. So going from 9500rpm to idle, it would over heat before I got to the ticket window...
Luckily for us in Denver, Bandimere's shut down is uphill. So I just ride 5th and pull the e brake (so my slicks wouldnt touch the fenders, but Ill have a 3 piece this year). Once I got slowed down a bit, Id touch the pedal.
Old Feb 5, 2012 | 07:59 PM
Martian's Avatar
I engine brake mine as well. Lets the oil come down in temp a little softer. I see nothing negative in doing so.
Old Feb 6, 2012 | 05:48 AM
slowboy90's Avatar
so im glad to hear everyones on stock calipers and all but are you guys really running an OE style rotor ie(not drilled, dimpled, slotted, etc)
Old Feb 6, 2012 | 06:53 AM
OE style rotor ie
yup
Old Feb 6, 2012 | 08:46 AM
slowboy90's Avatar
thanks guys
speedfreek128
14
Feb 26, 2009 10:01 PM
ninor
Acura TSX
12
Jan 17, 2005 08:24 AM
93SSPHatch
May 15, 2002 05:17 AM
garados
Apr 23, 2002 04:48 AM
InfamousRS
Jan 21, 2002 09:13 AM
