flywheel
Old Feb 13, 2007 | 01:24 AM
Winlight's Avatar
Default flywheel
whats better for drag racing,a light weight flywheel or a OEM weight flywheel?the car is about 2400 lbs with me in it and ill be running slicks,traction bars and drag coil overs
Old Feb 13, 2007 | 01:52 AM
ImportMotorSpec's Avatar
Default Re: flywheel (Winlight)
Depends on how good of a driver you are is what i always say. The less weight will cause the engine to drop rpm quicker during shifts. So, if you can shift fast go with the light weight.
Old Feb 13, 2007 | 02:23 AM
Winlight's Avatar
Default Re: flywheel (ImportMotorSpec)
i dont take my foot off the gas when i shift in my camaro,but i dont know how well ill do in the honda sence i havnt had a chance to drive it yet.my plan is to set my rev limiter to 8100 and my shift light at 8000.i think i can shift fast enough to stay off the limiter.if not then ill set the light to 7900.
Old Feb 13, 2007 | 03:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
if you are spinning it that high, and if it is goin fast enough, i would strongly suggest a flywheel that is SFI approved.
Old Feb 13, 2007 | 11:29 AM
litovi3tboi503's Avatar
Default Re: flywheel (boostedcivicsir)
its preference.. what do you like.. some prefer heavier oem ones some prefer light ones.. i prefer one right in the middle around 12 lbs
Old Feb 13, 2007 | 11:41 AM
Winlight's Avatar
dosnt a stock b16a2 make peak hp at 7600 rpms?
Old Feb 13, 2007 | 12:39 PM
PHDZINE's Avatar
My rule of thumb is to go as lite as possible. Other people might flame me on this but this is my own rule of thumb. I don't care if it's Na, turbo or Supercharged. The more weight you can remove from the rotating mass will speed up inertia.
FunForFree33
19
Mar 28, 2021 09:53 PM
yellowturbo
Dec 20, 2004 08:59 PM
Fergy82882
Sep 28, 2004 08:45 PM
romeirome1
Jan 15, 2004 02:55 PM
93B17A
Dec 17, 2001 07:26 AM
