FJO Injector driver or AEM?
Old Sep 16, 2006 | 06:02 AM
GDM S2K's Avatar
Default FJO Injector driver or AEM?
Im trying to decide what injector driver to go with on my s2000. the car is fully built with a 67mm turbo running 1600cc injectors. any input would be great. pros and cons of both devices would be very helpfull thanx in advance
Phil
Old Sep 16, 2006 | 08:45 AM
Turbocivic94's Avatar
Default Re: FJO Injector driver or AEM? (GDM S2K)
I run FJO injector driver and it works great.
Old Sep 16, 2006 | 09:32 AM
mec. pedri's Avatar
Default Re: FJO Injector driver or AEM? (Turbocivic94)
I have an AEM computer. Is it necessary to run a driver if I run 1600 injectors
Old Sep 16, 2006 | 09:59 AM
DaveF's Avatar
Default Re: FJO Injector driver or AEM? (mec. pedri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mec. pedri &raquo;</TD></TR><TR><TD CLASS="quote">I have an AEM computer. Is it necessary to run a driver if I run 1600 injectors</TD></TR></TABLE>
yes, or a resistor box.
Modified by dturbocivic at 2:32 PM 9/16/2006
Old Sep 16, 2006 | 10:23 AM
buck02's Avatar
no
it is not required because u still can use the honda driver but it wont open the pulse as fast and steadly hold the pulse it falls off so itsa a good idea to get the aem driver but not required no
the driver will incur you to get it to idle much better and easier when ur tuning not a rought idle liek the stock driver would
Old Sep 16, 2006 | 01:21 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GDM S2K &raquo;</TD></TR><TR><TD CLASS="quote">pros and cons </TD></TR></TABLE>
pros.
-better modulation/control of injectors, they are more precise, giving u more consistent afr/pulse width , most apparent at low pulse widths (ie partial throttle & idle)
-u gain duty cycle because they open the injector valve much faster than a saturated driver+resistor
-smoother idle, especially apparent with large injectors and huge cams
cons.
-cost
on my car with 1000cc and skunk2 pro 1's with the AEM injector driver my idle is at 900prm and is near stock
pettyboy69
Engine Management and Tuning
Mar 6, 2012 05:52 AM
t66crx
Apr 7, 2008 03:48 PM
turboedc2
Sep 14, 2006 02:06 PM
Turbocivic94
Mar 8, 2006 07:49 PM
R THIS
May 25, 2003 01:54 PM
