First time using full slicks, have problems!
Old May 4, 2009 | 05:09 PM
turbociv910's Avatar
Default First time using full slicks, have problems!
First off, thanks for viewing-
I am new to drag racing(with a fast-er car), most of my racing career has been dedicated to road course's.
My main problem is doing the burn out. Even with 205s on the rear, I cannot sit still, well even remotly have some resistance to get a good burn out. It usually consits of just dragging the rear wheels, not creating much smoke.
My routine is, I roll in the water box, spin them a little, roll foward then do a second gear. It has no problem spinning them, just the tires lock up and slide.
Should I do more of a burn out in the water box to help the tires not stick as well?
passes on slicks
12.0
11.8
11.7
11.4
little about the car-
DA integra
J1 trans/lsd
lsvtec 500+whp
18k rear springs
-.5 camber in front
And edit, this is not a joke.
Old May 4, 2009 | 05:21 PM
Garage 808 Hatch's Avatar
Default Re: First time using full slicks, have problems!
Do your burnout in the water box, let off the ebrake and continue the spin out of the box towards the line. then stop and stage.
Old May 4, 2009 | 05:25 PM
Urban_Indian's Avatar
I do my burnout in 2nd gear.
I get lined up in the water box, holding up the e-brake and I only hold it up for about 2-3 seconds while the tires get hot( ranging at around 7000 while the tires start to get warm and the car starts to move forward) I usually let the car smoke the tires for 3-5 seconds before I put my foot through the floor and let it hit the rev limiter( peddling it so that its not just pinned there) and I release the e-brake(at the same time) so that the car pulls itself out of the water box into the staging area.
I think you are not revving the car up high enough, fast enough, to get enough spin out of the tire thus the thing gaining traction and pulling you out of the box before you are ready.
Or do I have this totally wrong.
Old May 4, 2009 | 05:29 PM
JRSC01GS-R's Avatar
everyone has a different style they like, but when I do my burnouts, I roll through the water box and pull like 1 foot past it, then I stop, I only pull the ebrake while im on the 2step, once I let clutch out in 2nd gear, I pretty much drop ebrake at same time and let car roll forward spinning the tires
how far out of the water box are u pulling before u do your burnout? your tires may be too dry to really get a good burnout, do u have your 2step set up high enough to get the tires spinning right away? it mostly comes with practice, take the car out a few times and u will get it figured out.
Old May 4, 2009 | 05:33 PM
I also beleive im pulling to far foward into the rubber laid down by other cars.
Im releasing the clutch out around 5k, then jumps to rev limiter/pedle it.
Maybe im slipping it to much, giving it time to catch traction?
Old May 4, 2009 | 05:37 PM
sanman000719's Avatar
I had the ame issue this weekend i pulled into the water box stopped set the e brake hit 2 step at 5k rpms in 2nd gear let out the twin disk, and let them eat but it didnt last long as well as they didnt smoke alot either.
Old May 4, 2009 | 05:50 PM
96 GSR-T's Avatar
drop the clutch higher or try 3rd gear and a higher rpm and no e-brake, I had no issue just sitting still doing a burnout dropping the clutch at like 7k in 2nd gear no 2 step, then again I dont launch on the 2step either so IDK, only ran on a shitty track.
Old May 4, 2009 | 05:55 PM
IDK, i do all my burnouts in 1st gear, and cut Low 1.7's in a heavy low powered car. and cut mid 1.6's in my 400+hp ef. not great 60's, but good for the track conditions around here
Old May 4, 2009 | 05:58 PM
well i was doing 1st gear at first, and then went to 3rd during the day and 1.964 was the best 60 foot i had in a 400hp ef as well lol. since we seem to be having the same issue does it look like this
http://www.youtube.com/watch?v=N7zUEa8PL5U
Old May 4, 2009 | 06:05 PM
oops this is the one i meant actually
http://www.youtube.com/watch?v=yTcFceum0Fk
Old May 4, 2009 | 06:14 PM
96 GSR-T's Avatar
I dont see you dragging the rear tires. And you are shifting into 2nd gear way to early, I can hear it falling flat on its face.
EDIT: nice thread jack btw
Old May 4, 2009 | 06:17 PM
actually man i donno yesterday was the first event so 2nd early is totally possible on my part.
my e brake needs to be tightend cause it wouldnt hold it in place
Old May 4, 2009 | 06:27 PM
integrawow's Avatar
I have a DA and my burnout's suck also. The slicks do tack up from what I can tell. It would be nice to have a quality burnout though. I think it might just make my car a little more consistent. Maybe not though.
I tried a second gear burnout, and it sucked just like the first gear burnout did. Using my shitty e-brake doesn't seem to make a difference. It's probably because my e-brake doesn't hold the car all that good.
Old May 4, 2009 | 08:23 PM
atomikcoupe95's Avatar
3rd gear burn out is the best but it sucks on your tranny
Old May 4, 2009 | 09:13 PM
JRSC01GS-R's Avatar
try dropping clutch at 7-8k in 2nd and ride it out for a sec, that should be plenty of heat for tires
Old May 5, 2009 | 09:08 AM
well after watching my videos again i wasnt really hitting boost during burnouts either wich is probly why the car didnt sit very well lol lower wheel speed=more friction and causing the slicks not to get hot. My launches also seem to not be building my 8psi either according to datalog lol My fault
Old May 5, 2009 | 09:21 AM
96 GSR-T's Avatar
you dont need to build anymore than what you are now at launch, I can hear the tires spinning.... just dont panic and short shift 2nd gear, atleast ride 1st to the 60' if not a little further whatever it takes to not bog, it looked like as soon as the rpm's hit redline you just nailed 2nd gear.
Old May 5, 2009 | 09:25 AM
your probly right man i need seat time lol, but on the lighter side i had 4 passes with no redlights lol so i was pretty happy about that
Old May 5, 2009 | 10:50 AM
BoostR41's Avatar
like everyone is saying rev it higher before you dump the clutch in the box. I peddle it in the box to get a bit of smoke and as soon as I see the smoke over the fenders I drop the brake and at the same time push the peddle to the floor and spin out of the box. I dumped at 7-8k rpm in the box
JDMAF
Jul 18, 2013 03:58 PM
Broke EF
Apr 12, 2006 09:18 AM
Georgethefierce
Apr 16, 2003 06:05 PM
vtec69
Apr 3, 2003 08:38 PM
Lei Siew Long
Jun 9, 2002 01:54 PM
