first time at the track. with this setup
Old Jun 6, 2011 | 04:18 PM
boostontheD's Avatar
Default first time at the track. with this setup
just finished the new build. and got tuned on wed.
car made
the setup is
SOHC
vitara built block. stock length fjt rods
port and polished head
59500 cam
supertech springs skunk2 retainers. stock valves
precision 6262 turbo
go-autoworks backdoor fmic and piping
GE intake manifold
took it to the track yesterday for the first time.
last setup ran 11.9 with 300whp
goal this year is 10's
two best passes were
11.01@129mph 1.8 60ft
11.2@121 1.960ft missing fourth gear.
fasted mph was 133 on a 11.4 pass just bad 60ft.
had problems bogging 2nd gear.just wasnt riding the limiter long enough in 1st i think. and the burnouts were terrible. def has a mid 10 pass in it on more seat time and a better prepped track.
comments and tips welcome.
Old Jun 6, 2011 | 04:27 PM
TypeRfit's Avatar
RESIDENT
Default Re: first time at the track. with this setup
Nice run. Sounds pretty healthy
Old Jun 6, 2011 | 04:35 PM
thank you sir. car runs amazingly smooth. was tuned by brian husted at wrenches in des moines iowa. did a awesome job.
def would of made more power but i told him to stop when it made 475.
also the car is still on the stock axles that came from the factory.
Old Jun 6, 2011 | 05:22 PM
Newt Dog's Avatar
look's good man.. Nice budget build. I'm building a new setup myself this year.
Old Jun 6, 2011 | 05:54 PM
intevic94's Avatar
Nice setup. What are you revving it to?
Old Jun 6, 2011 | 06:12 PM
1st and 2nd taking it to 9k. 3rd only 8800
Old Jun 6, 2011 | 06:47 PM
turbociv910's Avatar
def better times with more seat time. i ran 11.40s my first night and ended up with a pb of 10.71 with time. congrats on the good power
Old Jun 6, 2011 | 06:52 PM
thanks man. def would like to get down to mid to higher 10's
next time im going to lower the tire psi just a little more.i was running 10psi this time. prolly drop it another psi or 2
Old Jun 6, 2011 | 07:43 PM
i ran 10 psi in my 25s, could have def ran lower but i liked the little spin, you def have the power to run faster than me!
i was in a heavy 99 em1
Old Jun 6, 2011 | 07:52 PM
theidealone's Avatar
Are you running slicks? Definitely could improve on the 60'. Once you do that, youll probably stop falling out of boost into 2nd.
I run 5.5psi in my 24.5x9.5-13s.
[EDIT] Setup looks great BTW. VERY VERY similar to my setup. Definitely making some good power. How much boost?
Old Jun 6, 2011 | 07:58 PM
SL0WEGG's Avatar
Nice times for the first time out. The burnout was painful to watch lol
Old Jun 7, 2011 | 04:38 AM
yes sir. M&H 23in tall on 15in rim. was running 10psi in them. il def run a little lower psi next time. maybe start at 8psi and go from there.
also it is on 28psi. only did one pull at 28psi on the dyno. told them to stop cause i was happy with that. def could of made more at that boost
Old Jun 7, 2011 | 09:58 AM
base-op.1320's Avatar
John you should come to brainerd and run the true street class, 62mm turbo limit there. We are leaving the 24th.
Old Jun 7, 2011 | 10:23 AM
Sick man! Yea, I would start at 8, and work your way down from there. 10 psi is definitely killing your 60'. You dont have as much sidewall with the 15" rim. So I dunno if I would run 6 or anything. But 7-8 would probably be perfect.
Old Jun 7, 2011 | 06:37 PM
H_WANTED's Avatar
very nice set up
Old Jun 7, 2011 | 11:07 PM
FarmYard's Avatar
good ****. hope to see 10's soon.
Old Jun 8, 2011 | 09:31 AM
d16z6Tcrx's Avatar
Very nice times. At what psi did it take to make that graph? Also switch to a 13 inch rim for the extra side wall and a 24.5 tire. This should greatly help your short track.
Old Jun 8, 2011 | 09:46 AM
give me some more info man. id like to go but also have to save up some money for a trip end of july
well i already have 15in wheels and slicks. even if i get 13's id still use 23's
23's are enough for me atm. and new wheels and slicks cost money. and when i already have a set il work with what i got ya know
Old Jun 8, 2011 | 11:34 AM
h22apwrd95's Avatar
24.5's will be way to tall at the moment for him. He still has a ton of mph left in 4th so stepping up to a 24.5 is going to slow him down. What transmission are you using? I forgot to ask that over on the other forum?
Old Jun 8, 2011 | 01:15 PM
boostek9's Avatar
car is moving john, keep doin what ur doin. its nice to have some good competition in the area, now we have more motivation to make more power and wack ur car, lol.
let us know if u ever need help or parts, always willing to help out a fellow racer
Old Jun 8, 2011 | 03:27 PM
welfarepc's Avatar
jesus 28psi... i cant wait to turn my boost up! i made 450whp on 20psi on my D series 6262... and it was insane then.
Old Jun 8, 2011 | 07:09 PM
stock gearing ex/si trans with quafie lsd
haha i want ya to wack it! only since yours is b series! def nice to have some people right around the same times to trade info with.
im positive it can make over 500whp on 28psi. it made the 475whp at 28psi the first pull and i said stop. no more pulls were made to change anything. def could of got more out of it.
Old Jun 8, 2011 | 07:14 PM
Look up map proving grounds for more info on race, two day event with huge party and nice people with funny accents lol. Any plans on a b series trans in your future?
Old Jun 8, 2011 | 07:39 PM
24.5 is definitely too tall for a D tranny. 23 is right where you want to be. Itd just be nice to have the sidewall from a 13. But you can still do well with the 15. I had friends running 10s, at my altitude, with D trannies and 22x8x15s.
Old Jun 9, 2011 | 11:38 AM
il look into it for sure. but idk if funds will be back up enough tho unfortunatly
i totally agree. im always looking for a set of wheels. but people want way to much. if rather buy new then pay to much used
