F.A.S.T help.
Old Aug 4, 2003 | 04:07 AM
jasonp's Avatar
Default F.A.S.T help.
I run a full drag crx 2.1liter gsr deckplate (95mm stroke) 440 injectors, jg intake, webcams, 84.5 wiseco pistons.etc... I problem is that I need someone with a good feul map and a/f map... please.................. my car falls on it's face when launching at 7000 rpms and drops to 3500 rpms, and spits and sputters it's *** off untill about 6500 rpms... I have a b16 tranny with 4.78 f/d (99-00 gears).. so any you TRUE DRAG RACERS want to share a good map with me.. I would be most gratefull... thanks.. jason...
Old Aug 4, 2003 | 04:18 AM
DaveF's Avatar
Default Re: F.A.S.T help. (jasonp)
doesnt your's have an "autotune" feature or something to that effect.?
Old Aug 4, 2003 | 05:13 AM
jasonp's Avatar
no it doesn't but it does have a/f correction...
Old Aug 4, 2003 | 04:27 PM
jasonp's Avatar
anyone else have any advise..I am willing to pay a fee for a good map program from a legit drag racer...
Old Aug 4, 2003 | 06:00 PM
TurboDANDEE's Avatar
u got PM
Old Aug 4, 2003 | 06:40 PM
2156cc's Avatar
Default Re: (jasonp)
I am running almost the same set up in my civic. What stand-alone do you have? Autronic? If you still need help just e-mail me at jeremylally@hotmail.com I will see if I can send you one of my maps.
Old Aug 4, 2003 | 06:47 PM
bambooluv's Avatar
Default Re: (2156cc)
He runs F.A.S.T
Old Aug 4, 2003 | 07:53 PM
TECH43 RACING INC.'s Avatar
Default Re: (bambooluv)
call darren at r&d 310-516-1003. im sures hes got a good map (starting point) you could get.
Old Aug 4, 2003 | 08:07 PM
Suprdave's Avatar
Default Re: (TECH43 RACING INC.)
Put it ona Dyno?
Old Aug 5, 2003 | 03:04 AM
DaveF's Avatar
harvs tuning set me up with a base map to get my car started. maybe you could try giving them a call
ps. i have a speed-pro but never gotten to use it yet
Old Aug 5, 2003 | 04:57 AM
jasonp's Avatar
I went to the track on sunday and that's when it went to sh*t. so my friend that knows a bit about speedpro said that it may be the cams that I have. (webcams) but these cams in the same motor same setup went 11.70's about 2 months ago.. I think it might be electrical but not sure.. timing is on the money but because of the deckplate you have to make sure you are on TDC.. any other help is more than welcome P.S. I have a Harv's base map and that got me to 11.70's ...thanks..
Old Aug 5, 2003 | 12:53 PM
PTR1's Avatar
You have to put it on the dyno and tune it with a wideband. Can't just race a car on a base fuel map like that, it'll never run right
Old Aug 5, 2003 | 04:14 PM
jasonp's Avatar
Hey, I think I have figured what my problem was ... Fuel itself.... I was using 104 octane then I jumped to 110 octane and that's when the car started to run like crap.. so I am changing fuel and I will be testing soon.. thanks and I will keep you up dated......jason
Old Aug 5, 2003 | 04:29 PM
saso
Guest
Posts: n/a
At first it sounds like you might have an electrical problem. It could be a hundred things. Fuel, ingnition, you really need to carry that thing thing on a dyno.
Old Aug 5, 2003 | 06:57 PM
rOby's Avatar
ur retarded right? that can be the only SANE reason ur "racing " the car on a basemap
Old Aug 5, 2003 | 10:07 PM
bambooluv's Avatar
Default Re: (rOby)
so jason enough people telling you to dyno man? hehe what about the 7grabd rev limit in 4th?-pete
b20turbocivic
Engine Management and Tuning
14
Dec 28, 2009 11:31 AM
B16A1-EF9
14
Aug 27, 2005 09:30 AM
tygsr
Aug 19, 2002 10:04 AM
