Extended wheel studs
Old Sep 25, 2002 | 02:50 PM
allmotorhatch's Avatar
Default Extended wheel studs
Do you need extended wheel studs for the bogart drag- on series rims?
Old Sep 25, 2002 | 03:25 PM
hybridreams's Avatar
Default Re: Extended wheel studs (allmotorhatch)
extended studs are required at pretty much all events if you're running slicks.
ExospeedAMcrx's Avatar
yes the bogarts require extended lugs.
Wil
Old Sep 25, 2002 | 08:34 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Extended wheel studs (exospeedAMcrx)
where can i pick up a set of extended wheel studs while we are on the subject.....?
Old Sep 26, 2002 | 07:30 AM
autoEXturbo's Avatar
you can get skunk2 or arp. i got mine from viren. Or you go with dss stage 5 axles(if you need them), you get extended studs with them. Probably cost alot more too though.
Old Sep 26, 2002 | 09:38 AM
Default Re: Extended wheel studs (SIXTYdashONE)
Got the Skunk2 lugs in stock.
PM or email me if interested.
Old Sep 26, 2002 | 09:39 AM
martini's Avatar
I use H&R studs.
But yes, you definitely need the extended studs.
Old Sep 26, 2002 | 10:45 AM
HT's Biggest Loser
thanks , i think i will need em soon, ill get abck to u...
Old Sep 26, 2002 | 01:43 PM
I'm gonna try to oredr them from exospeed
Old Sep 26, 2002 | 01:54 PM
skunked's Avatar
ARP are better studs than the SKUNK2 studs.
Old Sep 27, 2002 | 10:06 PM
tony1's Avatar
Default Re: Extended wheel studs (skunked)
I agree with that one...the skunk 2 threads are really weak and I've had to change a few of them. Not from crossthreading, just from continuous on and off of the wheels. We have used the arp for two seasons now and they are like new. ARP doesn't make them to fit honda though, you have to drill out the hubs and weld in the studs from the back. Don't worry though, you'll never have to change them!!
Old Oct 1, 2002 | 10:18 AM
Speedworks801's Avatar
Default Re: Extended wheel studs (tony1)
SAME EXPERIENCE, CHANGED MULTIPLE SETS ALONG WITH SEVERAL HUB/BEARING SETS TO THE TUNE OF $400 BUCKS; SWITCHED TO ARP'S COURTESY OF COMPTECH AND NEVER HAD ANOTHER PROBLEM
Good Luck
allmotorek8
Suspension & Brakes
26
Jun 11, 2009 06:29 AM
jimmhatch
32
Feb 11, 2007 12:37 AM
JDM_SOHC
May 7, 2006 07:47 PM
b19coupe
Aug 19, 2003 11:41 PM
Jared
Aug 13, 2002 02:10 AM
