Extended Lug install question
Old Nov 12, 2005 | 07:44 AM
Dublocivic's Avatar
Default Extended Lug install question
Do you have to press the hubs off to install extended studs on and eg? They look like they might clear.. Anyone have any insight? Thanks!
( The search is down)
Old Nov 12, 2005 | 08:36 AM
DxTrix's Avatar
Default Re: Extended Lug install question (Dublocivic)
Yes you do.
Old Nov 12, 2005 | 08:59 AM
Dublocivic's Avatar
Default Re: Extended Lug install question (DxTrix)
Thanks
Old Nov 12, 2005 | 06:08 PM
5thgenallmotor's Avatar
Good time to get new wheel bearings.
Old Nov 12, 2005 | 06:29 PM
eg crunkmonster's Avatar
Default Re: Extended Lug install question (5thgenallmotor)
https://honda-tech.com/zerothread?id=1402107
this link helps.
I just did mine. fairly easy. i didnt change my wheel bearing and its still good. just rent a sliding hammer and you are good to go. the rear is really easy.
Old Nov 12, 2005 | 08:48 PM
dunkd's Avatar
I did mine without pressing out the hubs.
1.) Remove rotors/calipers.
2.) Get a big hammer and bang the old ones out.
3.) Grind down the edge of the end of the studs so they will clear the backing.
4.) Get some washers and put them over the stud and then put on the lugnut and pull it through with an impact gun to get it in all the way.
5.) Spend the two hours you just saved doing it this way and go cruuuuusin.
Ive heard this way only works with EG's because they have a notch in the hub so the new ones will clear.
Old Nov 14, 2005 | 05:40 AM
Dublocivic's Avatar
Default Re: Extended Lug install question (eg crunkmonster)
Thanks for the link! That helps alot.. I didnt even think about using a slide hammer.
I do actually need to pull the hubs.. I forgot that I have new hubs that came with my DSS stage 5 axles.
Old Nov 14, 2005 | 05:57 AM
smokey2.0's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">I did mine without pressing out the hubs.
i did it that way with stock studs on my crx, i have to see if i can make the extended studs fit the same way!
Old Nov 14, 2005 | 07:49 PM
dunkd's Avatar
Default Re: (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">i did it that way with stock studs on my crx, i have to see if i can make the extended studs fit the same way!</TD></TR></TABLE>
yah they will fit, that is why u just need to grind down the side a little bit on the endtab.
Old Nov 14, 2005 | 11:49 PM
Calvinator's Avatar
Default Re: (dunkd)
yah they will fit, that is why u just need to grind down the side a little bit on the endtab.</TD></TR></TABLE>
good info, you just saved me lots of time. thanks. Also, ive heard its recommended to spot weld the back of the stud. Is that really necessary?
Old Nov 15, 2005 | 07:38 AM
mrbsponge's Avatar
i just ground down a small notch in the hub itself, cause i was tired of tearing up studs and replacing bearings. its ghetto but it works like a champ
Old Nov 15, 2005 | 11:44 AM
dunkd's Avatar
Default Re: (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">good info, you just saved me lots of time. thanks. Also, ive heard its recommended to spot weld the back of the stud. Is that really necessary?</TD></TR></TABLE>
if u have the means to do it then sure, if not i wouldnt sweat it. Just make sure you pull the stud through all the way...
kornerk12
Aug 8, 2008 08:32 PM
crv-techu
Jun 10, 2008 01:51 AM
ALLMOTOR CRX
Mar 14, 2007 10:08 PM
RTW DC2R
Feb 13, 2006 08:21 PM
spettinger
May 4, 2003 10:03 PM
