extended lug studs
extended lug studs
do you have to remove the bearing to install skunk 2 extended studs on the front of a 95 integra? i herd that you can pull out the hub with a slide hammer a bit and install them ? has anyone on here installed them before?
Re: extended lug studs (crv-techu)
Although it mayyy be possible, I'd recommend pulling the hubs off...
...so you can install the extended studs in NEW bearings and get it all out of the way
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crv-techu »</TD></TR><TR><TD CLASS="quote">do you have to remove the bearing to install skunk 2 extended studs on the front of a 95 integra? i herd that you can pull out the hub with a slide hammer a bit and install them ? has anyone on here installed them before? </TD></TR></TABLE>
There is the other way. Where you have to notch off the shielding by doing this you have to take each stud one by one. I have an article here somewhere it was done long time ago.
Quickridez_3
09-30-2008 04:08 PM
ALLMOTOR CRX
03-14-2007 10:08 PM
spettinger
05-04-2003 10:03 PM
