excedy twin disk help
Old Jul 22, 2010 | 06:27 PM
sanman000719's Avatar
Default excedy twin disk help
ok just picked my new disks up for my excedy twin with center plate.
1 disk is marked tm side (transmission) that would go toward the tranny?
2. the other is fw side (flywheel) does it the (fw) go toward the flywheel?
i had them this way before and it scared my flywheel bolts up some not to bad but some. did that happen due to the wear of the plates being so bad it allowed them to lose clearance and hit the bolts?
Old Jul 22, 2010 | 08:14 PM
MoiMotorsports's Avatar
Default Re: excedy twin disk help
okay you want the plates that are marked to be facing you when you install them if anything just give me a call
Old Jul 23, 2010 | 05:44 AM
sweet yeah I looked for installation instruction on there sites lastnight and didnt see anything except lining the friction plates up correctly.
ill holla at ya today
Old Jul 23, 2010 | 10:33 AM
boostedcivicsir's Avatar
Mr. Badwrench
make sure to line up the holes on the discs also as close as you can.
Old Jul 23, 2010 | 10:35 AM
yeah i read that on the website but I have 4 people with 4 differant opinions on wich way the disks go on lol, and excedy wont answer there phone
Old Jul 23, 2010 | 02:19 PM
done correct answer is emagining the disks attached to the flywheel and being able to read tm/fw
hotrodlincoln
Sep 26, 2006 04:10 PM
DsVtec2nrHBC
Mar 24, 2005 07:48 PM
275Performance
Apr 30, 2003 05:03 PM
vtec69
Apr 12, 2003 10:23 AM
3rdGteg
Sep 3, 2002 09:52 PM
