Evaluate my time slip
Old Aug 26, 2002 | 11:40 PM
milf H U N T E R's Avatar
Default Evaluate my time slip
R/T .768
60' 1.908
330 5.702
1/8 8.757
MPH 79.47
990 11.308
1/4 13.536
MPH 104.48
Temp 95
Relative Humidity 100
This is in a heavy *** 2800 lb. Teg with a built LS motor with a T3/T04E at 12 lbs. of boost running on 22x8x13 slicks at 10 lbs. Think I could break into the 12s with more boost 16 lbs., better 60 ft. and cooler weather? Should I drop the tire pressure more?
Old Aug 27, 2002 | 12:59 AM
sparkz's Avatar
Default Re: Evaluate my time slip (RAwDeeLuX)
work on your 60 ft times. a 104 trap could mean 13.0's if launched better. looks like a pretty hot day out too.
Old Aug 27, 2002 | 03:05 AM
wHOAlly's Avatar
Default Re: Evaluate my time slip (sparkz)
60' times in 1.6-1.7 and your perfect
2800 lbs sounds heavy, very heavy ?
[Modified by AkumaY, 4:06 AM 8/27/2002]
Old Aug 27, 2002 | 06:04 AM
CHEETAH's Avatar
Default Re: Evaluate my time slip (AkumaY)
1.6 and 1.7 60' in a FWD 2800 lb car is next to impossible unless its a RWD .. I personally have never seen it done, guess there is always a first.
Greg
Old Aug 27, 2002 | 07:29 AM
MikeMAN's Avatar
Default Re: Evaluate my time slip (CHEETAH)
ur 60ft almost look perfect, maybe on a cooler day you would turn a slightly better time....and as far as ur MPH, u are about where u should be for ET...
so for the conditions, pretty nice run..
cooler day, MAYYBE 12's..
nice setup!
Old Aug 27, 2002 | 09:10 AM
PROFILES2000's Avatar
Default Re: Evaluate my time slip (MikeMAN)
ive seen consistant 1.8 60 fts and the once in a blue moon 1.7 in an NA hatch. id say that your 60 ft seems ok maybe try for a 1.8
Old Aug 27, 2002 | 01:32 PM
URAS-J's Project D1's Avatar
Default Re: Evaluate my time slip (PROFILEGSR)
Ya i ve seen cars doing 12.9 2 the same trapspeed so im sure you could get lowere then 13.5 even tho your car is heavy im sure you can still squeeze a bit out of the 60ft time .
Old Aug 27, 2002 | 05:10 PM
pfcfutrell's Avatar
On a cooler day i have no doubt you could hit 12's. The performance of turbo cars varies drastically with the temperature so that 95 degree **** was holding you back for sure.
Old Aug 29, 2002 | 12:35 AM
wHOAlly's Avatar
Greg
well i figured he was wrong on the weight, 2800 sounds really really heavy, atleast to me it does....
Old Aug 30, 2002 | 09:21 AM
Urban Business
Guest
Posts: n/a
2800 is very heavy. 95% ouside is to hot. aslo how humid was it? what elivation? weather is 90% of the battle unless its nice outside cool and not humid
vaporboy12
Mar 9, 2007 06:44 PM
anothaRRR
May 1, 2005 02:31 PM
B18C1CYA
Jul 26, 2004 03:26 PM
jdmjeff
Feb 11, 2004 07:58 PM
pagong
May 9, 2002 11:36 PM
