engine dyno for tuning?
Old Aug 14, 2005 | 07:10 AM
1 2 NV's Avatar
Default engine dyno for tuning?
who has an engine dyno that i could send my motor to for tuning????
Old Aug 14, 2005 | 08:12 AM
Supernatural's Avatar
Default Re: engine dyno for tuning? (1 2 NV)
why not a dyno jet?
Old Aug 14, 2005 | 08:25 AM
280dragger's Avatar
jg engine dynamics has one!
Old Aug 14, 2005 | 08:41 AM
Garcia-Racing's Avatar
Chassis dynos are nowhere near as good as engine dynos.
Old Aug 14, 2005 | 09:04 AM
SpeedDreamz.com's Avatar
Default Re: (Garcia-Racing)
Jim Justice and Justice Race Engines.
http://www.justiceracingengines.com/dyno/
Old Aug 14, 2005 | 10:06 AM
1 2 NV's Avatar
Default Re: engine dyno for tuning? (SUPERNATURAL)
nothin wrong with a dynojet bell. its just that ive been ****** with my motor all yr trying to figure it out and it just isnt making the #s. its beyond me. my 1.8L was running faster than this 2L. last yr the 2L was running 2-3 1/10th faster than this yr. i guess i changed too much at one time and havent figured out the right combo yet.
hence, the reasoning for my post.
Old Aug 14, 2005 | 10:16 AM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">nothin wrong with a dynojet bell. its just that ive been ****** with my motor all yr trying to figure it out and it just isnt making the #s. its beyond me. my 1.8L was running faster than this 2L. last yr the 2L was running 2-3 1/10th faster than this yr. i guess i changed too much at one time and havent figured out the right combo yet.
hence, the reasoning for my post.</TD></TR></TABLE>
Send me your Dyno sheet and engine specs I can help you...
Old Aug 14, 2005 | 10:25 AM
1 2 NV's Avatar
Default Re: engine dyno for tuning? (MAX_CFM)
i dont have a dyno from this yr. we have fine tuned the AF ratio and used last yrs BIN file for a baseline. i changed 3 things since last year and have been track testing as much as possible. changing cam gear settings, watchin AF ratio etc, still to no avail.
i added a 70mm TB, PG rockers and JG sheetmetal IM over last yr.
EDIT: im about ready to throw my old **** back on. ive already put on my ITR IM just to see if that would change anything. the incrementals from last night showed the ITR IM to slightly put down better ETs than my JG, but that could be due to track conditions.
Modified by 1 2 NV at 11:37 AM 8/14/2005
Old Aug 14, 2005 | 10:40 AM
yup, a dyno is the only place to really tell what makes a difference.
tony1's Avatar
Put it on a chassis dyno man. Tuning a turbo car at the track is one thing, but putting together an N/A combination and trying to tune it at the track isn't going to get you very far. An engine dyno is great, but a chassis dyno will work just fine for what you need. Setting up an engine on an engine dyno is alot of time and money.
Old Aug 14, 2005 | 10:51 AM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a dyno from this yr. we have fine tuned the AF ratio and used last yrs BIN file for a baseline. i changed 3 things since last year and have been track testing as much as possible. changing cam gear settings, watchin AF ratio etc, still to no avail.
Modified by 1 2 NV at 11:37 AM 8/14/2005</TD></TR></TABLE>
That yur whole problem NO dyno..
a few degrees of timming on NA is like 30hp
Old Aug 14, 2005 | 10:53 AM
MAX_CFM's Avatar
also how hi are u reving it?
Old Aug 14, 2005 | 10:55 AM
1 2 NV's Avatar
im using the same timing MAP as i did last yr. i was on teh same 114 gas as last yr, then dropped to 112, now im down to 108 and still running the same.
revving to 9k.
Old Aug 14, 2005 | 11:00 AM
earl's Avatar
I believe those PG rockers will mess with your cam profile. You may not have the same cam specs you had last year
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">im using the same timing MAP as i did last yr. i was on teh same 114 gas as last yr, then dropped to 112, now im down to 108 and still running the same.
revving to 9k.</TD></TR></TABLE>
you changed bore size correct...
you will need to change your timing ....
Old Aug 14, 2005 | 11:02 AM
1 2 NV's Avatar
bore size is the same, crank same, head same (new valve job), cams same, JG IM, 70MM TB, PG rockers
Old Aug 14, 2005 | 12:00 PM
b19coupe's Avatar
I am going to chime in on the side of a chassis dyno. It's amazing how much changing one little thing can affect a tune. Dustin, I get the impression that you have an aversion to chassis dynos, take it from a dyno *****-they rock
Old Aug 14, 2005 | 12:19 PM
1 2 NV's Avatar
Default Re: engine dyno for tuning? (b19coupe)
naw, thats not the case at all todd. i just dont have anyone that can tune anywhere near me. my friend that mods my ECUs can tune but we have very little experience. we just have to kind of wing it on the knowledge we have been given through HT and other contacts via the internet. i live in a small SE washington town, we have no true tuners here on the eastside, just small timers sorta winging it. i guess the funny thing about it though is we have the 2 fastest all motor hondas in the NW located on the eastside of the state, go figure.
once i get ahold of the guys at the dyno facility ill see if i can work out an hourly rate for next weekend or so.
Old Aug 14, 2005 | 12:28 PM
JL's Avatar
JL
"official" BOTI dyno day at intec racing in kent, wa. on the 20th..
Old Aug 14, 2005 | 12:48 PM
ATS*Mark's Avatar
OG triple OG
Default Re: engine dyno for tuning? (JL)
wouldnt a chassis dyno be more effective?
Fabman
Sep 21, 2006 07:40 PM
turbo*s2k
Jun 12, 2005 12:49 PM
