Engine Claying...
Old Jan 12, 2005 | 01:35 PM
HotWheelz's Avatar
Default Engine Claying...
Do all 4 cylinders need to be done, or only one, after all, the install height and valve seat is the same on all 4 cylinders, so if one does the clay in one cylinder should it really matter in the other 3????
opinions on this ...
Old Jan 12, 2005 | 01:47 PM
allmotorgsrekk's Avatar
Default Re: Engine Claying... (HotWheelz)
i only clay one when i clayed my motor! good luck
Old Jan 13, 2005 | 04:12 AM
fabnewb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotWheelz &raquo;</TD></TR><TR><TD CLASS="quote">Do all 4 cylinders need to be done, or only one, after all, the install height and valve seat is the same on all 4 cylinders, so if one does the clay in one cylinder should it really matter in the other 3????
I have always done them all just to check consistancy. just to be extra sure. But then again when you degree cams your amusing that piston 1 has the same deck height as all the other cyl. So i assume its cool to clay just one. Unless you have had the valve seat cut recently in which i would do it because i trust no one .
dbsharp
Engine Machining & Assembly
Nov 3, 2016 05:41 PM
dfoxengr
Jun 20, 2006 05:05 PM
grenthang
Apr 29, 2005 09:13 PM
ImportsCRX
Nov 15, 2004 09:10 PM
se93
Mar 31, 2002 10:25 AM
