Electric water pump problems
Old May 19, 2003 | 11:01 PM
K20  EG's Avatar
Default Electric water pump problems
has anyone ever had probs with there electric water pump that Meziere makes ??
Anyone !!!
Modified by B20---Vtec at 12:28 AM 5/20/2003
Old May 20, 2003 | 06:18 AM
badCRX's Avatar
New User
Default Re: Electric water pump problems (B20---Vtec)
are you having problems with yours?
Old May 20, 2003 | 10:08 AM
K20  EG's Avatar
Default Re: Electric water pump problems (badCRX)
ya ...mine kept getting airpockets ...so i dunno whats going on with it ..
Old May 20, 2003 | 10:45 AM
b18bturbo's Avatar
we had the same problem you need to release the bleed valve and also your radiator fill point must be higher than the neck of the water spout on the head
Old May 20, 2003 | 11:09 AM
K20  EG's Avatar
Default Re: Electric water pump problems (b18bturbo)
OK GOTCHA....that makes sense ....my fluidyne sits a lil higher for some reason ...i will adjust it accordingly ...and check it again
Old May 20, 2003 | 11:24 AM
b18bturbo's Avatar
what you can do is lifthe readiato out of its bracket and then fill it it will gurgle and all the air will come out
Old May 20, 2003 | 02:25 PM
Jared's Avatar
Use quickbleed funnel to bleed the system.
Old May 20, 2003 | 04:01 PM
K20  EG's Avatar
Default Re: Electric water pump problems (Jared)
where do it get the quick bleed funnel ..i had a fluidyne ..will it fit that ??
Old May 20, 2003 | 08:39 PM
Dual Cams's Avatar
i'm just wondering what kind of electric water pump are you using and on what motor??
new_climber
16
Mar 12, 2018 08:56 PM
BB6-213
Jul 23, 2011 01:23 PM
blackeg
Oct 11, 2007 02:25 AM
cadougherty_67
Mar 29, 2005 06:21 PM
tominos
Sep 10, 2004 08:38 PM
