ebrake
Old Apr 13, 2009 | 05:40 PM
boostedb20z's Avatar
Default ebrake
whats the name of the ebrake setup that bolts to the floor on the passager side and has a handle coming up its like a hydro ebrake setup. sorry for the spelling
Old Apr 13, 2009 | 05:45 PM
1992Si's Avatar
Default Re: ebrake
If I get the correct answer do I get a prize, or do I have to phrase the answer in the form of a question ?
Would that be a staging brake ?
Old Apr 13, 2009 | 06:07 PM
Default Re: ebrake
thank you so much ryans dad lol
Old Apr 13, 2009 | 06:25 PM
Default Re: ebrake
can you run this staging break on drums cuz i dont fill like swaping them. so when i put this in do i just undo my rear lines off the prop valve and then run my one line out of the staging break into a tee and to my rears ?? just want to make sure b4 i get into this. thanks again
Old Apr 14, 2009 | 04:37 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: ebrake
CNC staging brake:
http://www.cncbrakes.com/hsb.asp?grp...412&subseries=
Old Apr 14, 2009 | 05:05 AM
hawkturbo's Avatar
Default Re: ebrake
Originally Posted by turbotypeR@SPEC
sorry noob ?? how mount this on integra dc2
Old Apr 14, 2009 | 05:25 AM
Default Re: ebrake
i just called them and they say to run it inline with my old lines and some people say not to cuz it can make for some problems at the big end of the track?????
Old Apr 14, 2009 | 06:09 AM
1992Si's Avatar
Default Re: ebrake
Think about how fluid dynamics works. If you have no air in the system, the in-line set-up should work.
I wonder if the "problems" come from the fact that you now have 2 reservoirs ?
I would think the manufactures would know best.
Old Apr 14, 2009 | 10:59 AM
reactone's Avatar
Default Re: ebrake
What are the advantages of a staging brake over say, a line lock setup to the rear wheels?
Old Apr 14, 2009 | 11:16 AM
1992Si's Avatar
Default Re: ebrake
You have a lot more adjustability with the staging brake, it's used to apply the rear brakes and drag the car forward into the staging beams. Then you can still use the line lock after the car is positioned.
That's how I understand it.
Old Apr 14, 2009 | 06:06 PM
TurboGoKart's Avatar
Default Re: ebrake
Which one is used to squat the rear of the car then?
Old Apr 14, 2009 | 07:58 PM
SOHCinWA's Avatar
Default Re: ebrake
I just cut the latch off of my stock e-brake lever... It has worked great.
Old Apr 14, 2009 | 08:04 PM
Default Re: ebrake
lololol
Not the same thing this is hydraulic power not cables pulled by leverage
Old Apr 14, 2009 | 08:08 PM
SOHCinWA's Avatar
Default Re: ebrake
lololol
Cable or hydro it dont matter..
Old Apr 15, 2009 | 09:21 AM
toyotaturbo's Avatar
Default Re: ebrake
LOL....I thought I was the only one who did that!!
Old Apr 15, 2009 | 09:44 AM
1992Si's Avatar
Default Re: ebrake
You can duct tape the button in also, if it's only for a short time.
Old Apr 15, 2009 | 10:21 AM
alonsobuiltmotors's Avatar
Default Re: ebrake
i run a staging brake it works great for me real nice for preload
OptxEm1
Suspension & Brakes
Jul 23, 2012 07:03 AM
Lewy. Dee Ayy
Oct 19, 2009 09:45 PM
alonsobuiltmotors
Feb 12, 2009 05:56 PM
project93cpe
Dec 4, 2007 05:20 AM
