The easiest way to.......
Old Mar 14, 2003 | 10:29 AM
Chuck P's Avatar
Default The easiest way to.......
Yes I did a search
Does anyone know what product works the best in getting up all the black tar on the floor boards?
Old Mar 14, 2003 | 10:31 AM
MARC P's Avatar
Default Re: The easiest way to....... (MrCrooks)
I would like to know also
Old Mar 14, 2003 | 10:37 AM
Austin's Avatar
Default Re: The easiest way to....... (MARC P)
Dry ice...
Old Mar 14, 2003 | 10:42 AM
Chuck P's Avatar
Default Re: The easiest way to....... (Austin)
dry Ice?
Old Mar 14, 2003 | 10:59 AM
ykracing's Avatar
yes, people use the dry ice to freeze the sound-deadening, then hit it with a mallot, and the stuff just shatters... then you just need to bag it up and throw it out...
also, you can use a heat gun, to soften it, and then scrape it off with a plastic scraper, followed by goof-off to remove the gooey residue...
but freezing it is by far the easiest...
Old Mar 14, 2003 | 11:26 AM
Chuck P's Avatar
Default Re: The easiest way to....... (trboCIVIC&WRX)
Thanks
Old Mar 14, 2003 | 12:16 PM
kill bill's Avatar
yea dry ice works, on mine i just went straight to the mallet, it worked just fine.
Old Mar 14, 2003 | 03:20 PM
skunked's Avatar
Default Re: The easiest way to....... (i need space)
Air Chisel (sp?)
Just be careful you don't put a hole in the floor
Old Mar 14, 2003 | 04:22 PM
Gmedalion's Avatar
Default Re: The easiest way to....... (skunked)
Air Chisel (sp?)
Thas what I did
Old Mar 14, 2003 | 06:54 PM
JSPECEX's Avatar
DO YOU guys think it is worth it becuase i was thinking about it to
Old Mar 14, 2003 | 07:09 PM
boosted3g's Avatar
Default Re: The easiest way to....... (JSPECEX)
i used a torch and a scraper. Works ok and but its a pain in the ***.
Old Mar 14, 2003 | 07:42 PM
VTEC-DA's Avatar
Air Chisel (sp?)
Haha, if your not careful, thats exactly what you will do. I remember the first time I ever used one. The shop I worked at had a really nice one, and the first thing I used it for was cutting up an old bug. Took me 3 hours with a air chisel and a Sawzall and the once whole bug was in about 15 pieces in a dumpster.
Old Mar 16, 2003 | 05:18 AM
SuperTwinz's Avatar
Yup dry ice makes it way cleaner to remove gunk.
bluenc-87
Paint and Body
May 18, 2009 06:02 PM
vtec2K9
Jun 19, 2008 03:42 PM
jaydmcrx
Dec 2, 2003 11:10 AM
all stock
21
Apr 28, 2003 03:55 PM
jdmcivicferio
Mar 30, 2003 02:47 AM
