e85 and fuel cell
Old Jan 11, 2011 | 08:50 PM
Civic89stdB16's Avatar
Default e85 and fuel cell
Im looking for a fuel cell thats e85 compatible. i cant find any i want a 5 to 8 gallon cell that i can fit in the back passenger side of my ef hatch to the right of the spair tire well. the tall one. Please if u know of a fuel cell thats e85 compatible lmk. thanks
Old Jan 11, 2011 | 10:03 PM
theidealone's Avatar
Default Re: e85 and fuel cell
What makes any of them not compatible? Ive heard that you just need to remove the foam. I would get an aluminum and pull the foam from it. Should be compatible from there...
Old Jan 11, 2011 | 10:18 PM
xohcef's Avatar
^^^^X2 logic? Just put the jegs cell in it that says gas/oil/synthetics compatible
Old Jan 12, 2011 | 12:27 AM
jegs and summit said all the plastic fuel cells have the o-ring on the filler lid thats not compatible. and yes the foam is a no-no with the e85 just like aluminum is. thats why i posted this. once again im not a noob.
Old Jan 12, 2011 | 03:42 AM
96 GSR-T's Avatar
lol you really think that Ethanol is going to completely errode that o-ring upon touching it? Worst case scenario it takes a year to wear out the o-ring (which I highly doubt).... they can be found practically everywhere.
You have to remember companies put stuff like that in the description to protect their **** if they start having gasket failures or w/e else, just like Walbro stated their 255 is not e85 compatible.
Where are you getting your E85 from in your area? Only pump I know of in DE is 1/2mi from my house.
Old Jan 12, 2011 | 06:11 AM
SPOOLINmatt's Avatar
Funny, I have an aluminum tank, aluminum fittings, and aluminum fuel rail, regulator, and E85 doesn't do **** to my parts. Do some more research. Its all that sits in my car.
Old Jan 12, 2011 | 06:19 AM
JayWest's Avatar
i've had a plastic 1 gal cell for over a year on e85 and no problems here
out of curiosity, whats the problem with the foam and e85?
Old Jan 12, 2011 | 06:33 AM
xohcef's Avatar
Relax Sally, I never called anyone a noob but myself. On a constructive note remember when everybody said the e 85 will eat all the rubber lines in your fuel system, just like I said in the other post 3+ years and 400+ passes and the e 85 hasn't eaten them yet. F that o ring. Run it.
Old Jan 12, 2011 | 07:50 AM
E85 is a no no with aluminum eh? Better find a cast iron head, intake manifold, fuel rail, FPR, etc.
Old Jan 12, 2011 | 08:14 AM
sanman000719's Avatar
lol@cast iron head
so much false information has been past around about e85, and stock blocks that people really will neve rever know untill they try them out for themselves
Old Jan 12, 2011 | 04:13 PM
victor.ek4's Avatar
Jesus..
We run E85 in EVERYTHING here in Brazil... No problems at all.
The only thing I do is put some 2t oil in the tank once in a while to lubricate the fuel pump and it's all good
Old Jan 12, 2011 | 06:35 PM
thanks guys for the help. in just ordering the plastics one with no foam.
Old Jan 12, 2011 | 09:14 PM
If the ethanol DOES have a long term effect on rubber or plastic, by hardening, I would opt for an aluminum tank. Just me though.
Old Jan 12, 2011 | 11:48 PM
BubsBoostedEG's Avatar
ur good man i have 4 different cars runnin e98 fuel cells withfoam stock tanks no issues somefor 5years now
Justin Olson
Welding / Fabrication
15
Jan 5, 2008 05:13 PM
integracivic94
Nov 22, 2006 09:07 AM
rotten
Apr 2, 2004 12:46 PM
b16_incarnate
Sep 23, 2002 07:07 PM
