e85 ?
Old Apr 28, 2012 | 12:10 AM
turbo_rsx's Avatar
Default e85 ?
Im trying to finish up my fuel system for my rsx but im wanting to know if my setup is built for 800+ on e85 my set up is
id2000
dual 044
walbro 400 (intank)
2L swirl pot
-10 feed
-8 return
will the walbro 400 supply enough fuel to the swirl pot to make the power?
some pics of the set up not finish yet
Old Apr 28, 2012 | 05:23 AM
dantamparacer's Avatar
Default Re: e85 ?
It looks like it should be sufficient, if I remember correctly most people using a similar setup don't even run a 400lhp in tank but have the return coming off of rail to the surge tank. Then another from the surge back to the tank. I have never run one of these set ups personally so I may be incorrect
Old Apr 28, 2012 | 06:26 AM
ChrisMillerRacing's Avatar
Default Re: e85 ?
The return line from the rail runs back to the surge tank and then you run an overflow from the surge tank back to the stock tank. So it doesnt matter so much what pump you have in the stock tank. Me personally, I'd always run at least a walbro 255 in there but you get the point. With all of the return fuel running to the surge tank, it's going to overflow and be full. The only way I could see it being a problem is if you were WOT in 6th gear for like 30 mins straight, lol.
Old Apr 28, 2012 | 06:36 AM
turbo_rsx's Avatar
Default Re: e85 ?
thanks thats what i was thinking but i wanted some professional advise
Old Apr 28, 2012 | 11:39 AM
Almtrhb's Avatar
Default Re: e85 ?
I used the fullblown kit wit aeromotive 340, 2000 cc injectors, -10 feed AND -8 return made 861 on 29psi E85... So im sure your setup is good for it.
Old Apr 28, 2012 | 12:11 PM
turbo_rsx's Avatar
Default Re: e85 ?
861 @ 29psi was is your setup thats some good numbers
B_Swapped93
Jul 22, 2015 04:08 AM
thegatekeeper14
Welding / Fabrication
Mar 28, 2010 05:06 PM
BB6-213
Jan 30, 2007 04:06 AM
KStuned
Mar 17, 2004 09:20 AM
KStuned
Mar 12, 2004 09:44 PM
