Drag Wheels....Will these work
Old May 16, 2009 | 01:35 PM
Boosted_01 R's Avatar
Default Drag Wheels....Will these work
Hey guys I have a 2001 Integra Type R, was wondering if this wheel spec will work. Tire is a 24.5/8.0/15 M/T
Rim Diameter (in): 15 in. Rim Width (in): 8.00 in. Backspacing (in): 4.500 in. Offset (mm): 0.00mm
OR
Rim Diameter (in): 15 in. Rim Width (in): 7.00 in. Backspacing (in): 4.000 in. Offset (mm): 0.00mm
Thanks
Old May 16, 2009 | 03:03 PM
1992Si's Avatar
Default Re: Drag Wheels....Will these work
You'll want the rim at least as wide as the slick.
I think you'll be ok with the 4.5" backspacing. Someone else may know for sure.
Old May 16, 2009 | 03:13 PM
ExospeedAMcrx's Avatar
Each slick has its specifications on what rim width is recommended to use.
Either of those wheels will actually work. The 15x8 may be a better rim to use though.
Old May 16, 2009 | 03:56 PM
1992Si's Avatar
I knew someone with knowledge would check in soon.
I believe that's Will, you can trust what he say's.
Old May 16, 2009 | 04:27 PM
turbotypeR@SPEC's Avatar
25 Year Member
I used a 15x8 when I had my type R.
Old May 16, 2009 | 08:52 PM
THATS LOOKS SOOOO SICK, with the slicks. I was running stock ITR wheels with my slicks, they work fine, but want something wider.
Whats the backspacing and offset on your 15x8, if you remember ?
BTW any more pics of the R?
Thanks for the input guys
Old May 17, 2009 | 06:24 AM
The common backspacing for most Honda setups are between 4 and 5" Either should be fine, it just depends on how far you want the tire to stick out of the fender. You also have to consider the tire size you're planning to use. Of course the wider the tire(such as 9-10" wide) the more you want it away from the inside of the fender so it clears the supension parts.
Old May 17, 2009 | 10:50 AM
vivid 02's Avatar
On my ITR I have Bogarts 15x8 with 4.5 inch backspace.
Old May 17, 2009 | 11:13 AM
JdMhEaD's Avatar
On my ITR i ran STOCK ITR wheels with 24.5x8.0x15's
I ran 8psi in them. and had a best 60 foot of 1.73 (i was easy on the car out of the hole, bogged it everytime) This was running 13psi in 1st gear
Old May 17, 2009 | 11:14 AM
JdMhEaD's Avatar
Never had a rubbing issue either
Old May 17, 2009 | 08:23 PM
Was your offset 0? Would you say you had a pretty good turning radius? I see some guys making 3 point turns at the end of the track to come back on the return line, lol
and for the hell of it, here's my R
This should be the official "Type R's on Slicks" Tread, lol
Old May 17, 2009 | 10:21 PM
Japankid's Avatar
any more pics of 5 lug on slicks
Old May 17, 2009 | 11:12 PM
vivid 02's Avatar
I don't know what the offset was. I have a good turning radius but I am on small 22 inch slicks. Mine does not rub anywhere.
Here are some pics to give you an idea of how much the wheel sticks out of the fender.
Old May 18, 2009 | 12:19 AM
Mr. Em1's Avatar
bogarts looking nice on there, 15x8's are good
Old May 18, 2009 | 05:38 AM
BoostR41's Avatar
I ran 15x7 rota's for a year and had no issues. The next year I ran 15x8 Rota's with no issues.
you have PM
Old May 18, 2009 | 07:57 AM
dpetro1's Avatar
you have PM
what offset on the 15x8"
Old May 18, 2009 | 08:14 AM
E85B18's Avatar
Damn! Are these 26" tires?
Old May 18, 2009 | 09:16 AM
BoostR41's Avatar
I cant remember it was a group buy the ITR guys did.
these were 26" drag radials on my car just to throw it out there:
Old May 18, 2009 | 01:15 PM
E85B18's Avatar
Sweet!! Thanks for the pic. What size 26's? How well did it drive on the street?
Old May 18, 2009 | 03:02 PM
25 Year Member
Mine were 4.5" backspacing and yes, I was running 26x8 Goodyears. It is pretty funny how the "new" thing is running 26" tires. I was running them in 03.LOL
And yes, I have more pics:
Old May 18, 2009 | 08:35 PM
cotorresgee's Avatar
Danny what happen to your ITR? Looks clean!!!
Old May 19, 2009 | 04:33 AM
BoostR41's Avatar
I always ran 235/60/15 BFG's or M&H bias plys on the street. it didnt drive real bad but it didnt corner at all with the M&H.
On a side note I remember Danny's ITR from back in the day. It ran good from what I remember
HotboxedTypeR
May 14, 2015 01:39 PM
SlammedEG6
Jul 24, 2010 06:40 PM
Vw1320x
Mar 15, 2007 11:44 AM
HX_Guy
Oct 10, 2001 12:29 PM
