Drag radials
Old Jan 30, 2016 | 09:02 AM
94boostedhatch's Avatar
Icon5 Drag radials
I want to get a set of drag radials for my 94 hatch with 3 piece front to use for Dyno an transport I have a set of 15x8 rota slips 40 offset is anyone running 275/55r15 Mickey thompsons I think they would fit but I don't want rubbing issues
Old Jan 30, 2016 | 09:24 AM
Default Re: Drag radials
*275/50R15 part number 3753r
Old Jan 30, 2016 | 11:13 AM
DA9_LEO's Avatar
You should be fine with clearance as long as alignment is right and especially with 3 piece front end
Old Jan 31, 2016 | 08:50 PM
G-FX's Avatar
i just brought some rota slipstreams 15x8 +38.. I used the offset calc with my 8.5 wide street rims, with 23 offset and 225 tires... based on that difference i dont see how its going to work with the knuckle.. so Ive ordered 25mm spacers just in case
Old Feb 3, 2016 | 10:59 PM
kr3w108's Avatar
I know that MT recommends using a min of a 9" wide rim for the 275.
Old Mar 7, 2016 | 07:38 PM
eg:R's Avatar
I pull the trigger on these tires and the ride height is high on the front end. What height is everyone running with these tires or on any taller tires(26in) . Should I equally balance the ride height the same for front and rear? Right now my front is higher. I'm trying to make height adjustment now before doing my alignment tomorrow
Old Mar 7, 2016 | 07:53 PM
kr3w108's Avatar
for proper weight transfer raising the rear will be better.
b16bri
Apr 10, 2008 12:54 PM
SOHCD16y8
Jun 8, 2007 03:14 PM
SOHCD16y8
Jun 8, 2007 03:13 PM
SOHCD16y8
Jun 8, 2007 03:12 PM
B18CchampHatch
Apr 4, 2007 08:50 AM
