dohc zc
Old Nov 16, 2012 | 07:15 PM
crazyridha's Avatar
Default dohc zc
Is there any way i can rewire a 5 wires dizzy to 7 wires???
I swapped my zc engine from my 1988 crx si to 1991 civic si..
Now the problem is i dont have a engine harness for my civic and trying to use the one from my crx but the plug on the driver side by the resistor box is different...tried rewiring it and left the two wires hanging since the wires from the crx has 5 and from the civic has 7...tried starting it no sparks...i was told that i need the right engine harness for the civic and the right dizzy for the motor...any suggestions or can i use the one i got right now nut need some modification...pls help...im broke to buy more parts for these set up...anything will help...thanks..
Old Nov 16, 2012 | 10:28 PM
SonicRacing1's Avatar
Default Re: dohc zc
use a 91 civic SI engine harness junk yard maybe, are you in socal hit up "Richiewerks" he can wire up ur existing harness an make it work
Old Nov 19, 2012 | 08:17 PM
Mikeybreu's Avatar
Default Re: dohc zc
I need help modifying my 1991 civic dx hatchback engine harness to convert to mpfi from dual port. Step by step breakdown or a link that breaks it down if anyone could help. Been away from EF ownership.for 10 years n havin real hard time
Old Nov 19, 2012 | 09:21 PM
turbo-2nr's Avatar
Default Re: dohc zc
check the ef section this section is only for drag racing
90goldhatch
16
Oct 21, 2007 06:36 PM
redwards
May 29, 2007 06:44 PM
Turbo Dan
Apr 11, 2005 03:02 PM
neogeo
21
Jul 24, 2004 06:53 PM
zccrx
Mar 23, 2003 02:50 PM
