Dogbox Problems
Old Sep 27, 2011 | 07:58 PM
kantspell's Avatar
Default Dogbox Problems
ok so im working on a transmission for a friend who has a liberty dog box and a tilton triple carbon clutch and this is what the OEM reverse syncro looks like...has anyone seen this happen before or have any idea why this might be happening..can this just be removed or do i still run it...Here is the picture
Old Sep 27, 2011 | 08:27 PM
nonvtecallmotor's Avatar
Default Re: Dogbox Problems
You do not use ANY syncros in a liberty. Reverse has never had a syncro even stock.
Old Sep 27, 2011 | 08:39 PM
SynTeg's Avatar
lol
Old Sep 27, 2011 | 09:19 PM
.adam.'s Avatar
just put it in backwards since its the reverse sychro
Old Sep 27, 2011 | 09:44 PM
kantspell's Avatar
Wow I am amazed at the ignorance have any of y'all even opened up a trans?
Old Sep 27, 2011 | 09:50 PM
.adam.'s Avatar
i get ***** deep in trannys all the time
Old Sep 27, 2011 | 09:52 PM
GodFather of Boost's Avatar
Hondas actualy have a syncro for reverse.
I really dont know why it happens exactly but it always happens when you drag race. just take it out. u really dont need it.
Old Sep 28, 2011 | 07:23 AM
wmac's Avatar
T M I
Old Sep 28, 2011 | 10:24 AM
Blown90hatcH's Avatar
ITR and GSR's have a 5th/reverse syncro on the top of the stack.
OP, Do you have a picture of it assembled? Using a cuff?
Old Sep 28, 2011 | 11:32 AM
kantspell's Avatar
this is it with out the snycro
i was not sure if it would be ok to just take it out but we are going to give it a shot
Old Sep 28, 2011 | 11:35 AM
kantspell's Avatar
once we get a new third gear.
Old Sep 28, 2011 | 04:03 PM
SPOOLINmatt's Avatar
just leave that synchro out, thats what i do, it IS the reverse synchro. best thing to do is put it in a gear before going into reverse...so you don't grind the **** out of it without that synchro.
Old Jun 28, 2012 | 12:10 AM
kantspell's Avatar
ok now looking for a bit more help. took reverse snycro out and now cant get in to reverse engine running or not. i left the spacer in. any input will be appreciated.
Old Jul 1, 2012 | 10:27 PM
kantspell's Avatar
how are yall shifting? full throttle? clutch or no clutch?
Old Jul 1, 2012 | 11:03 PM
FlewByU352's Avatar
I full throttle into reverse all day! Wide open that bitch!
Old Jul 2, 2012 | 02:05 AM
zakura R's Avatar
I'm running the sincro on my liberty and some time give
E abit of problem going on reverse but what I usually do go to 1ro gear first them reverse is been working so far for me if u find a better way let me know about it thanks
Old Jul 2, 2012 | 04:12 AM
DDTECH's Avatar
LOL
Some of the replies are wow.. you would think people would know transmissions..Nope..lol
Old Jul 5, 2012 | 06:29 AM
badrex38's Avatar
i run a gforce gear set and just "flick" the clutch when i shift.
Old Jul 5, 2012 | 06:47 AM
vtekthis's Avatar
^^^ are you retarded?
Old Jul 5, 2012 | 07:16 AM
Divers's Avatar
Originally Posted by kantspell
When you see this happen to reverse or 1st it is usually caused by a dragging clutch. Being that yours is a triple I can almost guarantee it.
As for the synchro, you can remove it. I would also remove the synchro cone it rides on. Its common to not get into reverse sometime if the engine is not running, especially if the reverse teeth are flattened. It just means the teeth on the idler are lined up with the main shaft. Roll the car alittle and try again. Should go in.
Old Jul 5, 2012 | 07:29 AM
PRO1's Avatar
[QUOTE=vtekthis;47571801]^^^ are you retarded?[/Q
No his just from BRE
Old Jul 5, 2012 | 07:53 AM
If it still doesn't work even by rolling it forward alittle and maybe even try putting it in R while rolling. If nothing works try changing the shift change assembly. it may be the SF shifter. Had an issue with 1 not going in R. They took care of it right away.
Old Jul 5, 2012 | 03:34 PM
MR.johnson's Avatar
LOL @ some of these replies. if the clutch is not disengaging 100% it will wear 1st and R.
Old Jul 6, 2012 | 09:44 AM
badrex38's Avatar
no BRE parts on my car. my trans is g force built
Old Jul 14, 2012 | 05:14 AM
kantspell's Avatar
ok so there are different reverse gears for a b-series trans (the difference is the gear height) that is was stopping the trans from going in to reverse. i have also left out all the reverse stuff out and it works fine thanks for the info
01PYTypeR#1140
Jul 7, 2012 10:04 AM
SPOOLINmatt
Transmission & Drivetrain
Jan 31, 2010 03:22 PM
dai-18t
Jun 4, 2008 01:49 PM
joshsss
Aug 1, 2006 09:55 AM
austrian type-R
Jun 10, 2003 03:37 PM
