do they make 23" slicks?
Re: do they make 23" slicks? (whatVTEC)
you guys help me decide what size slicks i should get.
im ging turbo next year and will have 350whp w/ my eg hatch b18c1 w/b16tranny. what size slicks should i get for finishing at like 8000rpm's in 4th gear??
i think 23's. do you guys think that is a good size or do you think i will have to hit 5th gear??
also will vx rims fit 23x8x13? and will they fit 24.5x8.5x13??
Modified by megotvtec at 8:08 PM 8/17/2004
Re: do they make 23" slicks? (megotvtec)
VX rims is not the way to go for big slicks like that .
I would get at least 24s with the turbo set up . I have
23s right now on a all motor setup and I finish the 1320
in 4th at about 8300 ish .. That's with a stock GSR tranny too
Re: do they make 23" slicks? (lovitalracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovitalracer »</TD></TR><TR><TD CLASS="quote">VX rims is not the way to go for big slicks like that .
in 4th at about 8300 ish .. That's with a stock GSR tranny too </TD></TR></TABLE>
ya and you also run 11 flat.
my track is also 4424ft. above sea so i only expect to be running mid 12's
know of any cheap rims that will do good with those slicks??
transmission selected: 94-01 US B16A/ITR
1st gear 3.230
2nd gear 2.105
3rd gear 1.458
4th gear 1.107
5th gear 0.848
Final drive4.400
Tire diameter in inches 23.0
Gear ShiftRPM Speed @ 8000 RPM
1st N/A 38.5
2nd 5214 59.1
3rd 5541 85.3
4th 6074 112.4
5th 6128 146.7
RPM in top gear at 70mph: 3817
"The 23's show 4th gear finishing @112 and that is with the b16tranny
Tire diameter in inches 24.5
1st N/A 41.0
2nd 5214 63.0
3rd 5541 90.9
4th 6074 119.7
5th 6128 156.3
"the 24.5"show 4th ending @119
what is a mid 12sec 1/4mile honda's trap speed?
also where can i find some Bogarts or welds? i searched google. nothin
and does nobody make 23.5" or 24" slicks???????
Modified by megotvtec at 9:28 PM 8/17/2004
Modified by megotvtec at 9:36 PM 8/17/2004
1st gear 3.230
2nd gear 2.105
3rd gear 1.458
4th gear 1.107
5th gear 0.848
Final drive4.400
1st N/A 38.5
2nd 5214 59.1
3rd 5541 85.3
4th 6074 112.4
5th 6128 146.7
1st N/A 41.0
2nd 5214 63.0
3rd 5541 90.9
4th 6074 119.7
5th 6128 156.3
Well that all depends on your will spin , plus you have lots more top end power .
On the all motor cars Mid 12s is around 109-112 ish . Dont " me on that .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megotvtec »</TD></TR><TR><TD CLASS="quote">transmission selected: 94-01 US B16A/ITR
1st gear 3.230
2nd gear 2.105
3rd gear 1.458
4th gear 1.107
5th gear 0.848
Final drive4.400
1st N/A 38.5
2nd 5214 59.1
3rd 5541 85.3
4th 6074 112.4
5th 6128 146.7
1st N/A 41.0
2nd 5214 63.0
3rd 5541 90.9
4th 6074 119.7
5th 6128 156.3
Modified by megotvtec at 9:36 PM 8/17/2004</TD></TR></TABLE>
Hi megotvtec; 8/23-13 or 8.5/24.5-13 ( SORRY ) I missed your post.
John@M&H-Hashims
1st gear 3.230
2nd gear 2.105
3rd gear 1.458
4th gear 1.107
5th gear 0.848
Final drive4.400
1st N/A 38.5
2nd 5214 59.1
3rd 5541 85.3
4th 6074 112.4
5th 6128 146.7
1st N/A 41.0
2nd 5214 63.0
3rd 5541 90.9
4th 6074 119.7
5th 6128 156.3
John@M&H-Hashims
do you think i might hit 5th gear w/ the 23's?
cause i would like to go with the smallest slicks possible as long as i dont hit 5th gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovitalracer »</TD></TR><TR><TD CLASS="quote">Well that all depends on your will spin , plus you have lots more top end power .
On the all motor cars Mid 12s is around 109-112 ish . Dont " me on that .</TD></TR></TABLE>
is this about right? will a mid 12sec car trap out @112? cause like i said erlier i have the b16 tranny and 4th gear traps out at 112 in 4th but the 24.5 dont trap out till 119. i wish they made 23.5" or 24"s
Smarter than you
1st gear 3.230
2nd gear 2.105
3rd gear 1.458
4th gear 1.107
5th gear 0.848
Final drive4.400
1st N/A 38.5
2nd 5214 59.1
3rd 5541 85.3
4th 6074 112.4
5th 6128 146.7
1st N/A 41.0
2nd 5214 63.0
3rd 5541 90.9
4th 6074 119.7
5th 6128 156.3
Also factor in that your trap speed is an average of the last 66ft. of the track. So if your trap speed says 110 you probably crossed the finish line about 115.
I would go w/ the 24.5 M&H's.. Should give u just enough room w/ your rev limit/gears to cross the finish line w/ out shifting to 5th. Also, ive seen them work really well on a 300whp car so you definitly have enough power to push them.
1st gear 3.230
2nd gear 2.105
3rd gear 1.458
4th gear 1.107
5th gear 0.848
Final drive4.400
1st N/A 38.5
2nd 5214 59.1
3rd 5541 85.3
4th 6074 112.4
5th 6128 146.7
1st N/A 41.0
2nd 5214 63.0
3rd 5541 90.9
4th 6074 119.7
5th 6128 156.3
Re: do they make 23" slicks? (SlicksMH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH »</TD></TR><TR><TD CLASS="quote">Hey Guy's help me out here is megotvtec pushing, 249HP or 350 HP.
John@M&H-Hashims </TD></TR></TABLE>
right now im at 249whp@8300 208wtq@5100 w/nitrous
but next year i will be getting my block sleeved ang getting lower compression pistons&rods w/ gerrett t3/t4 t??67possibly
my whp goal is 350
Modified by megotvtec at 6:49 AM 8/20/2004
my whp goal is 350
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovitalracer »</TD></TR><TR><TD CLASS="quote">I have
this is why i think i should get 23"s because this guys finishes the 1/4 @ the end of 4th w/23"s and he runs 11 flat
Smarter than you
my whp goal is 350
Modified by megotvtec at 6:49 AM 8/20/2004</TD></TR></TABLE>
oh ok, do the 23's then for now.. If you run the car enough by the time u make 350whp u should need new slicks anyways. the 23's should be perfect for ur power and gears right now. when u make the 100more hp, do the 24.5's.
my whp goal is 350
Re: do they make 23" slicks? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">
oh ok, do the 23's then for now.. If you run the car enough by the time u make 350whp u should need new slicks anyways. the 23's should be perfect for ur power and gears right now. when u make the 100more hp, do the 24.5's.</TD></TR></TABLE>
Hi DIRep972; I talked to megotvtec last night and the 23's would be right but he would be real close to the rev limiter. So he wanted to go with the 24.5 because he is going turbo soon. So I told him just bump up the air pressure and get the slicks spinning on the 24.5, untill such time he make his mod's.
John@M&H-Hashims
John@M&H-Hashims
street dreams
01-08-2006 09:13 AM
street dreams
10-24-2005 07:58 PM
