Dec FS Thread
Old Dec 10, 2014 | 05:37 PM
  #26
blade0314's Avatar
Default Re: Dec FS Thread
TESTING WATERS: my short block 99mm h22a4 with rosko racing k2h crank. for those of you who don't know this has a 99mm k24 crankshaft in it that was modified with a oil pump drive flange. it has the following
I'm located in long island ny hit me up if serious 516 342 0318
-inline pro sleeved h22a4 55mm mains block 90mm bore
-rosko racing modified 99mm modified crank (at dampener/cnc timing hub/custom oil pump drive)
-carillo rods 1.51 R/S ratio (awesome for longevity of cylinder walls and piston rings)
-custom cp max compression max dome pistons roughly 15:1
-brand new rod and main bearings
-new front and rear main seals
-modified oil pan with new gasket
-block shaved for h2b
-oil girdle clearanced for rods
-oil filter cooler
-rear coolant pipe with thermostat housing
-ks tuned balance shaft delete kit
-h23 manual tensioner
-oem water pump
-modified oil pickup tube and stick (so you can read oil level accurately
-arp head studs
Old Dec 10, 2014 | 05:40 PM
  #27
BIGTUNA's Avatar
Lenso 13" Drag Wheels 225 Shipped 48 States
PCS 5v 0-250 PSI Sensor (No Plug/Pigtail) $65 Shipped
Old Dec 10, 2014 | 09:16 PM
  #28
hardcore97's Avatar
never used JB 6266. 950 shipped OBO
Old Dec 11, 2014 | 08:41 AM
  #29
toddone's Avatar
I am considering selling my drag Crx Project. Tubular chassis. Set up for b series. Will not part out. All custom control arms. Fully adjustable chassis. Full tubular chassis from front to back. All custom build control arms, trailing arms. Chassis is build into cage. Will accept all reasonable offers. What you see in the pics is what you get. Comes with solid aluminum motor mounts for b series and dry sump. Dont waste my time with lowball ridiculous offers. It is not crucial that I sell. Over $10k in chassis. Has brakes. Lexan windows. New glass windshield. Locater in East Tennessee. No delivery. Cash at time of pick up. Car has no vin. Bill of sale.
Old Dec 11, 2014 | 05:31 PM
  #30
crxmanror's Avatar
NEW B&R Breather Tank - $220 FREE Shipping
CNC machined bungs and filter tubes
Interanally baffled design to keep oil inside breather tank
Fully tig welded
Anodized Black
Laser etched logo
3 Earls Ano Tuff -10 Caps Included
3 New Filters with Chrome Tops as pictured Included
92-95 Honda Civic 1 Piece Headlights - $120 FREE Shipping
Brand new, Never used
Black Housings
Amber Corner
Brand NEW OEM Honda K24 oil pan - $80 FREE Shipping
Oil pan was only used to cover bottom end while assembling engine
RSX Type S shift Box & Cables - $200 FREE Shipping
Used shifter box and cables in excellent condition
Box already trimmed and ready for install in a swapped car or great spare parts to have
Old Dec 12, 2014 | 07:23 AM
  #31
bottlefedintegra's Avatar
Default Re: 91 DA drag car $4500.00
25.5a spec roll cage NHRA cert. expired Chrome Moly Strait axle rear (Anglia spindle) Aero space rear brakes Wilwood master cylinder OEM front brakes CNC staging brake with line lock (rear) CNC clutch pedal with clutch stop and clutch switch for launch and WOT shifting Strange Adjustable Coil over (rear) Omni Power Adjustable coil over (front) Ken Kustom Traction Bars Simpson Chute Engine Plate Safe Craft fire system Removable steering wheel JAZ aluminum seat JAZ 3 gallon fuel cell RCI 5 gallon cell and pump for intercooler 1200 hp water to air intercooler with lines 16 v Battery and charger Lexan windows Autometer Gauges ( volt, oil temp, oil press, water temp) Fiberglass one piece front and rear deck Aluminum rear wing Forward facing 321 stainless steel turbo manifold ( Burns Stainless collector / comes with 2 -44mm turbosmart waste gates) also has 4 egt bungs Weld Magnum 15x10 (Center powder coated black) Weld Magnum 15x4 ( Spindle mount / powder coated black) MT Tires front and rear Z 10 B series oil system ( complete with pan, pump brackets) Waterman sprint 400 fuel pump ( 5.8 GPM) Waterman B series cam drive Aeromotive regulator ( 13113) Aeromotive billet filter ( 12310) Precision 1600 cc injector Daytona Wide Band O2 ARC switch panel.. I also have and extra ls block and crank, cable b series trans and a bunch of misc. parts that can all go with the car. Needs to go I need the space and I have no plans to race in the near future, I also have the title for the car and its clean if that matters...pics upon request.....ALSO..the front now is not painted because i added a hood exit exhaust and had a few cracked fixed..car has been in the garage for 2 years on jack stands..i just hate to see it sit.
Old Dec 12, 2014 | 06:14 PM
  #32
nonvtecallmotor's Avatar
Albin's B-series Gearset 4.09 final drive. Needs 3rd gear dog ring replaced. SOLD
Old Dec 13, 2014 | 11:03 AM
  #33
neonkid's Avatar
Weldon 2035a $550 shipped
Old Dec 13, 2014 | 01:16 PM
  #34
$MIKE$'s Avatar
Couple of parts I have for sale pm or text for pics more info
Hydro Gsr trans with quaife LSD in perfect condition comes with speed sensor $1200 shipped
FIC 2150cc injectors for a b series bnib $600 shipped
Black scatter shield for b series been used dps motorsports $140
Tial 44mm mvr waste gate black bnib with all springs everything bought it from real speed a bout 2 months ago $330 shipped
Used 50mm tial bov works great comes with 2 springs $190
Lenos slicks with 24.5 tires $500 shipped
Itr crank perfect $350
B18c5 block no Pistons rods crank $350 81.5 bore
Full race intercooler with garret core one side is back door used for about a month. 3.5 thick 24" long. 550$
B series solid motor mounts painted black 220$
Ati street damper $250 used
Old Dec 14, 2014 | 07:17 AM
  #35
backyardtech's Avatar
i have a set of twm 52mm itb's for sale for b16/itr heads, i comes complete with vacuum block,550cc injectors with clips,fuel rail,fuel regulator,tps sensor,iat sensor,and fuel pressure regulator. i want $1000 obo located in swampscott ma. willing to ship at buyers expense. message me through here or text me at 6178003143 if interested.
Old Dec 14, 2014 | 12:54 PM
  #36
90dxhmt's Avatar
Please add 3% for paypal. All prices are shipped in lower 48. Phone number [cell] is 250-612-7697 and email at demersmp@gmail.com
Rywire OBD1 Budget D & B-series Tucked Engine Harness comes with ID injector adapters and alternator OBD 0+1 - OBD2 adapter.Perfect condition. Sells for $484 plus shipping. $325 shipped.
Innovative billet solid mounts for 92-95 Civic & 94-00 Integra B series. Can include engine bracket as well if you need for $40 more. $200 shipped
B18A/B+B20 timing belt,water pump and tensioner. Used for dyno time and a few passes at track. $50 shipped.
Old Dec 16, 2014 | 07:09 PM
  #37
209lsr_ly's Avatar
GForce Dog Box with the 4.4 final
WaveTrac 28 spline LSD
DSS Pro level axles
Welded casing
Speedfactory gear selector
Gforce welded fork
will come with 8 GForce gear oil for the box
This box was only tested on a 270whp all motor setup with 3 hits, never seen any harsh abuse, shifts like a beauty, Gears are all new
asking 9000 with everything
or 6000 without axles and lsd
3000 for axles and lsd
Areomotive A1000 red fuel pump with inline filter and 3 new filter
asking 250 obo plus shipping & paypal fees
Fast Brake willwood drag brake setup
never ran just mounted
asking 460 shipped plus fees
DTR k series header 450
Lenso 13x8 4x100 with MH 23x8x13 (plenty of life left on the slicks) 400
ZEX 100 direct nitrous setup for a k series manifold with a 10lb NX bottle
all lines, clamps, and brackets asking 350
hasport k series mounts 300
alittle dirty tho
pictures will be up asap if it doesn't have it already
"""ALL PARTS DOES NOT INCLUDE SHIPPING OR PAYPAL PAYMENT FEES""
Old Dec 17, 2014 | 08:54 PM
  #38
JDM-JAMES's Avatar
parts are located in San Diego, California 92114 local pickup is welcome 619-813-5149
paypal verified and accepted add 4% to total cost
*PROBE Forged high compression 84mm 13.1 pistons i have 2 boxes of these includes wrist pins and clips i have 2 boxes $275 Shipped Each
*PROBE Forged low compression 84.5mm pistons 9.2.1 includes wrist pins and clips $275 Shipped
*WEISCO D-series d16 75mm 9.1 pistons includes wrist pins clips and rings all new $375 Shipped
*D16y8 auto intake manifold good for d17 or d16y7 manifold swaps comes as shown $45 Shipped
*b16/itr edelbrock victor x manifold cut open and ported $375 Shipped
*D-series d16 d15 custom intake manifold $375 Shipped
*Custom sch40 stainless b-series ramhorn looks to be ac compatible comes with stainless 3in 4 bolt downpipe and 38mm dumptube the manifold has one broken bolt in it but will be removed before shipping this is a really heavy duty and quality piece $600 shipped
*Garrett t3/t4 60 trim .63 ar 4 bolt exhaust turbo less than 1k miles shaft play does not exist turbo is in excellent condition $475 Shipped
*B-series UGR cam gears exactly like skunk 2 $120 shipped
*skunk 2 d16 d15 cam gear *65 shipped
* d16 d15 silver cam gear *55 shipped
*d-series vtec cam turbo regrind never used $200 shipped
*d16vtec d16y7 d15b rocket motorsports valve springs $110 shipped
*h22 rocket motorsports valve springs $110 shipped
*D-series ferrea valve springs and titanium retainers brand new $310 shipped
*B-series b16 itr first gen skunk 2 intake manifold $125 Shipped
*h22 custom turbo manifold very long merge collector t3 and t4 flange and 38mm waste gate flange $325 Shipped
Old Dec 18, 2014 | 04:46 PM
  #39
GT30EK's Avatar
Two used 8an Kinsler Monster Mesh Fuel Filter 10 Micron. Only have about 30 passes on them in good shape. $40 Each plus shipping, Paypal.
Used Comp Clutch twin disc. Still in good shape just upgraded to a Carbon/Carbon clutch. $400
Used Tilton Hydraulic Throwout SOLD!!!!
Old Dec 20, 2014 | 01:07 PM
  #40
kungfuSiR's Avatar
ATS/Carbonetic Twin Disk Carbon/Carbon Clutch.
Purchased in 2012 and used for 2 seasons. I bought a rebuild kit for it from ATS who are the manufacturers of the clutch on behalf of Carbonetic last year to have as a spare. The clutch was used in our Time Attack car, and held 400whp and 250ft/lbs of torque without any issues. Removed from the car in perfect condition, we decided to go with something simpler and less aggressive.
This clutch has the 1350kg pressure plate option. The clutch has an MSRP of $2600 brand new, and the rebuild kit was another $1400.
Asking $1000USD plus shipping. Item is located in Canada but international and shipping to the US can be arranged.
Old Dec 21, 2014 | 05:07 PM
  #41
Almtrhb's Avatar
End of the Season Sell: I have a Borg Warner 72mm turbo. It has 4 lic passes, 3 full passes total on this turbo. My first hit on a soft pass I went 170mph.
The compressor measures 72/100 and the Turbine wheel is 87/81mm, it has a Ceramic coated 1.10 Ar housing. The Turbo sells on DP website for $2850 will sell for $***1700*** Not including Payal fees or Shipping....
Any questions feel free to Hit me at 714-388-7303 Thanks
Old Dec 22, 2014 | 05:18 AM
  #42
10sec4door's Avatar
F/S hondata coil on plug with billet dist cap and dizzy included 4130 coil hold down plate and custom rywire engine harness for plug and play install. Does not include coils unless you want to pay xtra for them. 850 shipped.
Old Dec 22, 2014 | 08:12 AM
  #43
dbang003's Avatar
I have the following parts left over from parting out my turbo civic that was a drag race then road race setup. All parts have very low miles on them as the car saw very limited street driving. More details about each part within the list below.
Parts are located in Central NJ. Prices are OBO and do not include shipping, paypal fees, etc. Contact via PM or at dbang003@aol.com
Competition Clutch B Series Twin Disc $800 – maybe 1,000 miles on clutch, used for 1 autox and 2 track days at NJMP and driving to/from events. No launches or drag passes on clutch. Also includes proper flywheel bolts.
Golden Eagle GSR B18C1 Intake Manifold and BBK Throttle Body $500 – maybe 2,000 miles on manifold setup. Also includes Golden Eagle TB Cable Bracket, OEM IAC, and Hondata gasket. Will not part.
Hasport Mounts for B Series in EG/DC $300 – maybe 2,000 miles on mounts. Also includes T-bracket to fit EG/DC. Will not part.
Mishimoto X-Line Radiator for Civic (Half Rad) $250 – maybe 1,000 miles on setup. Also includes Mishimoto aluminum shroud and 14” SPAL fan. Kept temps rock solid at 195* during lapping sessions on the road course on my turbo setup. Will not part.
Thermal R&D 3" EG Exhaust $325 - 3" Vband flange at connection to downpipe
Driveshaft Shop Stage 2 B Series Axles $200 - pictured, used but in good condition
B Series Axle (1 Set) $50 - not pictured, used but in good condition, had them for a backup set
B Series Shift Linkage $100
JIC Magic Front Upper Strut Bar $75
JIC Magic Rear Upper Strut Bar $75
More parts and caged shell will be listed once I have pictures. See link for updates https://honda-tech.com/sale-10/civic...-more-3233212/
Old Dec 22, 2014 | 02:13 PM
  #44
OBRJosh's Avatar
::For Sale::
Brand New In Box Hondata Traction Control System. I paid $595 i would like to get $550+ Fees, i also have 2 Front ABS Sensors That I Will Include For An Extra $50 If Wanted, Pm Me or Email me at Jdelcorte@gmail.com
Old Dec 24, 2014 | 06:49 AM
  #45
tscook3's Avatar
Parting out my 800+ hp race car and have the following parts up for sale- lots of good stuff 800-1000 hp parts!!!
- Hub City Performance custom dual backdoor intercooler kit using Garrett 3.75" core good for 900+ includes 3" aluminum TIG'd cold side piping with vanjen flange $800 (SOLD!!!)
- Tial 50mm bov- $150 (SOLD!!!)
- Like new GE sleeved GSR B18C long block good for 900+ hp motor has less than 100 street miles and few hits at the track
- Golden Eagle sleeved and line honed 83mm B18C
- Manley Turbo Tuff I Beam Rods
- CP flat-top 9.8:1 pistons with upgraded wrist pins
- Fresh micro-polished GSR crank
- Golden Eagle main studs and head studs
- Ported B16A head
- Supertech dual titanium valve springs and retainers, Crower valves
- Skunk 2 Pro 1 + cams with AEM cam gears
- Motor is brand new, everything bought new including all new parts from
Honda/Acura... have receipts on machine work and internals! $5,000 for complete long block ready to go!
- GSR hydro transmission
- Stock GSR gear set
- MFactory LSD
- MFactory long first gear
- CNC Werx Cuff
- Trans is in awesome condition, comes with speed sensor! $1,100 firm
- Competition Clutch Triple Disc for B Series Like New!!! $900
- Complete 1,000+ hp fuel system ready to go
- FID 2000cc injectors e85 compatible
- Dual Bosch 044 fuel pumps
- Stock tank sumped with Synapse sump kit two -8an feeds
- All Russell Pro-Classic black nylon hose and black fittings, two -8ans feeding
pumps merged to -10an feed to rail and -8an return to tank
- Fuel Lab regulator
- Black Golden Eagle fuel rail with -10an fittings
- $1,700 for complete fuel system, would like to keep together.
- Lenso VPD black slicks with like new MT 24.5 x 9 x 13 slicks, 2 hits on slicks $500 +
shipping (SOLD!!!)
- Custom SFWD aluminum catch pan $125
All parts are plus shipping / paypal fees! Everything like new. If you are interested, please text me at 717-658-4482 as I do not get on here often. All parts located in Chambersburg, PA.
Thanks!!!
Old Dec 27, 2014 | 04:48 PM
  #46
kte324's Avatar
Default **EG Drag Car Shell w/ Chromoly Cage** Clean Title
1993 Honda Civic Cx
Clean Clear Title
10 Point Chromoly Cage built by CCE to NHRA Specifications
5 Gallon RCi Fuel Cell
36mm Hubs
RCi Aluminum Drag Seat w/ EG Seat Rails
PCI Bronze Front Suspension (Solid Aluminum) Bushings
All Other Bushings Are Prothane
New Balljoints, Inner & Outer Tie Rods, Wheel Bearings, Brake Rotors & Pads
Extended Wheel Studs
New Fenders
Rolling on stock suspension and steel wheels
**Car comes as pictured in the recent photos, no hood or bumper.**
*****More Info & Pictures Here ---->>>https://honda-tech.com/vehicles-sale...title-3229000/
Price: $1300 or best offer. Text/Call 706-627-9865 for more info or pictures. **Pick-up only**
Old Dec 28, 2014 | 05:54 PM
  #47
jdm knight's Avatar
For sale. Full-race b series top mount $700 plus shipping. Full-race drag intercooler 4.5" thick single back door with vanjen flange welded to it. $600 plus shipping. Tial mvs 38mm wastegates. V-band. $400 for both plus shipping. Contact info 5712466897. Text for faster response
Old Dec 29, 2014 | 12:39 PM
  #48
johnls's Avatar
Fs:
Precision 1000cc Low impedence injectors 200 obo
Tempest racing intercooler 500hp core 250
Tempest racing b series forward facing t4 divided flanged for two 44 or 46mm wastegates 799 do 100off
Tempest racing t4 divided b series topmount flanged for dual 44 or 46mm wastegate 899 do 100off
Tempest racing b series bottom mount 495 free shipping
Aeromotive fuel pressure regulator with gauge and lines 120
New avid s2000 diff mounts 175
B series oem itr pistons and rods 75
New s90 tb 225 for 70mm b series 250 for 74mm k series
New Comp clutch k series stage 4 b series stage 4 325 each
Aem single cam fuel rail 60
Str h22 fuel rail 75
Located in mechanicsville md take paypal and credit card also can ship for extra any questions pm or text me 2402161030 thanks
Old Dec 30, 2014 | 06:17 PM
  #49
zuptidi's Avatar
IPG brake booster delete kit (EG/DC)
Comes with
Delete plate
Tilton master cylinder
Brake lines from mc to prop valve for eg hatch
Paid 260 shipped
Asking 220$ shipped
Used for a week if that
Old Dec 31, 2014 | 09:35 AM
  #50
thebrowneg's Avatar
love fab b-series top mount twin scroll 44mm flanges $550 shipped text or call (617)285-8199
