Corner balancing question
Old Nov 6, 2008 | 12:16 PM
underpressure02's Avatar
Default Corner balancing question
I am playing around with my scales again and wanted to see if the cross weight should be 50 / 50 on a drag car? I have 65% of my weight up front and 35% in the rear. My RF/LR is 51.8%.
Old Nov 6, 2008 | 12:18 PM
T4 Neon's Avatar
Default Re: Corner balancing question (underpressure02)
IMO its more important to make LF = RF. Equal weight results in equal traction.
Old Nov 6, 2008 | 12:33 PM
E Town DSM's Avatar
Default Re: Corner balancing question (T4 Neon)
From what ive seen on the pro cars we try to have as much weight up front. and try to keep side to side even as stated above. The older pro car was i believe 85 percent front weight.
Old Nov 6, 2008 | 12:53 PM
rota92
Guest
Posts: n/a
Default Re: Corner balancing question (E Town DSM)
I vote for getting a decent motor in that pig
Get it as much in the front as you can, and have them equal. Diagonal weights are nice but if it's going skew the front a good amount then leave it be.
Old Nov 6, 2008 | 04:38 PM
redboost10's Avatar
Default Re: Corner balancing question (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4 Neon &raquo;</TD></TR><TR><TD CLASS="quote">IMO its more important to make LF = RF. Equal weight results in equal traction.</TD></TR></TABLE>
in my opinion this is all that counts as well. the rear will only differ within 100lbs, from what ive noticed with the fwd cars ive balanced.
corner balancing is one of the funnest things to do to me
Old Nov 6, 2008 | 05:15 PM
1junkycivic's Avatar
Default Re: Corner balancing question (redboost10)
Does this help and what does it help?
Old Nov 6, 2008 | 05:20 PM
redboost10's Avatar
Default Re: Corner balancing question (1junkycivic)
it helps tremendously and it helps the car go straight off the line, equalize (if thats a word) the traction between the two front tires during launch so it lowers your 60fts, helps with stability somewhat as well.
when you do corner balance your car, put the slicks with the amount of air your going to run them at, at least somehwere in the ball park.
with this, comes toe in/out (out in our case), camber...
Old Nov 6, 2008 | 05:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">it helps tremendously and it helps the car go straight off the line, equalize (if thats a word) the traction between the two front tires during launch so it lowers your 60fts, helps with stability somewhat as well.
with this, comes toe in/out (out in our case), camber...</TD></TR></TABLE>Thanks,maybe one day I will do that.
Old Nov 6, 2008 | 06:01 PM
Boostfed86's Avatar
GOod read... In for more info.
Old Nov 6, 2008 | 08:29 PM
Well I just got back in after playing around all night. I was about half way through balancing it and then I decided I was going to lower the back about another inch and the front about 1/2 inch to lower the CG. So I had to start all over again. My front left is 40lbs heavier then the right and my rear is alot closer. I took all the weight out of my car for this weekend but when I put it back in, the right will be a lot closer. I also did a 50/50 cross weight. Going to get it aligned tomorrow and see if it helps my 60 foot at all this weekend.
kb58
Jan 11, 2006 07:36 PM
msinsky14
36
Jan 10, 2006 04:21 AM
rice r0cket
44
Jun 3, 2005 10:43 AM
Scean
Mar 23, 2004 10:37 AM
scorched0
Jan 8, 2004 03:48 AM
