compression ratio vs timing
Old Mar 3, 2010 | 08:39 PM
lwct100's Avatar
Default compression ratio vs timing
lets say you have 2 engins, one with 8:1 , and 10:1 compression ratio every thing eles is the same in the set up turbo .ect , how differnt can the timing numbers be under boost let say 45psi(s372) ,max rpm10,600 on c16. Can you be way more agressive on timing with the lower CR one?
Samuels
May 26, 2007 08:34 PM
1.8T_EG
Apr 29, 2003 04:46 PM
