CNCWerx CSS Block Cut In Half!!!!
Old Apr 2, 2012 | 05:13 AM
  #26
trickeng's Avatar
Default Re: CNCWerx CSS Block Cut In Half!!!!
Originally Posted by luck4rmkc
When the process is completed have you found the need to do another hone on the cylinders? Is there any shift, out of round or taper measurable after?
ABSOLUTELY!!!! It is always recommended to get the motor bored after the process. While the distortion is minimal because the fitment is perfect. Any time you squeeze a tube there will be some distortion unless you can get all the way around each cylinder, which obviously can't happen.
With that being said I've done at least 20 motors which where already built and simply taken apart and put back together after the css process. I just make the press a little lighter for those motors and it doesn't seem to affect it.
Old Apr 2, 2012 | 05:31 AM
  #27
2000GSRTypeR's Avatar
Wish I knew about this before I dropped my block off last Thursday at the machine shop.
Old Apr 2, 2012 | 05:34 AM
  #28
trickeng's Avatar
Knew what?
Old Apr 2, 2012 | 05:36 AM
  #29
About the CNCWerx process.
Old Apr 2, 2012 | 05:39 AM
  #30
Especially when I could of just dropped my block off to you since I am only in Rhode Island and you guys are not that far away from me.
Old Apr 2, 2012 | 12:17 PM
  #31
GEN2 LS's Avatar
Loved
so if I have a stock bore motor 81mm already built with rods/pistons, if I sent you that current block. After you finish the process with the block would it require a overbore, or could I re-use my old pistons?
Old Apr 2, 2012 | 12:28 PM
  #32
trickeng's Avatar
All I can say is that I've done a bunch of pre-bored/stock bore motors without issue, but stock bore builds are not ideal and I will not guarantee zero distortion.
Old Apr 2, 2012 | 05:00 PM
  #33
GEN2 LS's Avatar
Loved
oh ok, well if I had to go to 81.5mm or even 82mm could I send you guys the pistons along with the rods? I would have to go with the nippon piston on a eagle rod combo, how do you get the cast piston to fit on a forged rod?
Old Apr 2, 2012 | 05:20 PM
  #34
trickeng's Avatar
You would only send pistons if you want us to also b&h the cylinders and rods if you wanted us to assemble the shortblock.
We have nippon racing pistons in-stock with wrist pin locks so you can use forged rods.
Old Apr 3, 2012 | 07:25 AM
  #35
slobalt77's Avatar
looks like ill need to pick up a spare block and some new pistons and give this thing a try. seeing people making well into the 600's and 700's and them staying together has sold me on this product.
Old Apr 3, 2012 | 07:41 AM
  #36
hello1320's Avatar
I will have one of these blocks...brand new....at Honda day....come by marc p pits
Old Apr 3, 2012 | 04:33 PM
  #37
1SiC 3DR's Avatar
Well, this is exciting, since usually the weakest part of Honda sleeves is at the top most of the time, this could be a very cheap alternative to spending 800-1200 bucks having a block sleeved, and would be super cheap to have a spare short block laying around. I like it........
Old Apr 3, 2012 | 06:39 PM
  #38
sgnlab's Avatar
Tuning one mañana!!!
Old Apr 4, 2012 | 08:05 PM
  #39
m3tech95's Avatar
x2....i still have my B16a2 stock complete swap laying around as a spare to my sleeved GSR setup im building, this fits right into that budget to get a spare motor together with pistons/rods bored out to 81.5mm....and no failures to date? Impressive.
Old Apr 4, 2012 | 08:59 PM
  #40
hello1320's Avatar
So the block has to be honed and decked...and that's not included in the job ? Price wise I mean
Old Apr 5, 2012 | 05:10 AM
  #41
Waiting on results sir.
Old Apr 5, 2012 | 06:23 AM
  #42
lsturbohatch10's Avatar
can you pm me a price for this process w/ the bore hone and deck?
Old Apr 5, 2012 | 08:32 AM
  #43
B-Seriesdelslo's Avatar
Just sent my block out this morning to get this process done on my ls block, Cant wait to try it out
Old Apr 5, 2012 | 09:45 AM
  #44
lsturbo33's Avatar
All the results that I have seen so far are all on race gas. I would like to see a street car pushing pump gas with one of these blocks.
Old Apr 5, 2012 | 10:48 AM
  #45
JRSC01GS-R's Avatar
About how much these run with install and bore+hone?
Old Apr 5, 2012 | 03:52 PM
  #46
sgnlab's Avatar
Was hoping to put down 700 but the dyno we were on sucks!!! This car has been running over 600 for over 6months, but it wouldn't hold anything over 500/19psi without slipping/loosing rpm signal. So we called it a day and will be bringing it to the track. That will be more of a test anyway.
Old Apr 10, 2012 | 03:20 PM
  #47
sgnlab's Avatar
Car went 11.0 at 15psi. Car felt super strong, but track was very cold up here in NH so car was all over the place. Will be going back next week to turn it up.
Old Apr 10, 2012 | 03:51 PM
  #48
sanman000719's Avatar
how is the cooling on these blocks after the process
Old Apr 10, 2012 | 03:59 PM
  #49
sgnlab's Avatar
I know of at least a dozen streetcars running the CSS and haven't heard one complaint of running hot.
Old Apr 10, 2012 | 04:04 PM
  #50
nice
