clutch line/slave setup
Old Oct 27, 2014 | 07:11 AM
jarvis199's Avatar
Default clutch line/slave setup
Having some issues with clutch engagement on 9500 rpm shifts and was wondering if you guys are doing anything special to get the most from your hydraulic system? Right now i am on all oem items as far as lines and such, with a comp twin disk clutch. car makes mid 600s in the upper gears. I was thinking just fresh fluid and an aftermarket line to replace the oem soft line?
any input appreciated!
Old Oct 28, 2014 | 02:22 PM
Turbo-LS's Avatar
Default Re: clutch line/slave setup
I have brake line from the firwall to the slave, new oem slave and omni power master cylinder with Clutch masters FX700 the omni makes the pedl a bit harder but actuates the clutch much quicker and less pedal travel. Seems to be working good for us 10k shifts no problem
Old Oct 28, 2014 | 04:05 PM
Steeve_Civic's Avatar
Interesting...
Old Oct 28, 2014 | 05:05 PM
DraginX's Avatar
Pretty sure in the cc twin disc literature it recommend you change the master and slave, and to a ss braided line. It's been a while since I read it though.
Old Oct 28, 2014 | 07:23 PM
Turbo-LS's Avatar
I meant to type braided line not brake line
Old Oct 29, 2014 | 10:07 AM
luck4rmkc's Avatar
We use stainless braided hose from master to slave with oem master and slave with no issues 10k+ rpm...
Check out link in my sig if you are looking for a place to get a stainless braided line made.
Old Oct 29, 2014 | 12:42 PM
seelback's Avatar
Im also using a omni master cylinder with a russel line that replaces the oem soft line, and fx500 unsprung. pedal pressure does increase but pedal travel goes down alot, making shifts much faster, some people think i have a automatic cause of how fast i shift. If you have a short throw shifter the omni master cylinder is a must. most people dont realize that putting on a short throw shifter with oem pedal travel master cylinder makes you shift faster but your clutch pedal speed stays the same.
Old Oct 29, 2014 | 03:23 PM
Natural Aspirations's Avatar
How on earth do you guys preload and drive on that Omni MC with a twin? I had one years ago on a exedy stage 1 and it was a nightmare.
Old Oct 30, 2014 | 03:36 AM
seelback's Avatar
just takes time to get use to it. it actually isnt bad to street drive, I have tons of track seat time so its just another day at the office for me.
Old Oct 31, 2014 | 07:59 AM
a1320addict's Avatar
Tilton Hydraulic Release Bearing w/ flow valve and you won't look back.
90civicbns
Aug 1, 2013 12:50 PM
jdm kidd
Jan 15, 2011 06:07 AM
jdm kidd
Jan 14, 2011 08:22 AM
sideswiped
Jun 13, 2010 01:35 PM
jeff652
Jun 28, 2001 07:13 PM
