CLUTCH LINE
Old Jan 14, 2011 | 04:48 AM
jdm kidd's Avatar
Default CLUTCH LINE
HI GUYS I RECENTLY ORDERED A CLUTCH LINE AND IT CAME IN -4 TEFLON
MY PROBLEM IM HAVING IS WHEN I BLEED THE CLUTCH IT DOESNT ENGAGE I HAVE BEEN TRYING IT FOR ABOUT 3 HOURS, I PUT NEW SLAVE CYLINDER NEW LINE AND FITTINGS BUT THE MASTER CYLINDER IS ORIGINAL 92' OEM
DO YOU THINK THE LINE IS TOO BIG BEING A -4 OR HAS THE MASTER CYLINDER GONE OUT?
MI GUESSING IF SOMEBODY ELSE USES -4 CLUTCH LINE THEN ITS NOT THAT AND HAS TO BE MY MASTER
Old Jan 14, 2011 | 05:02 AM
crazes's Avatar
Moderator
Default Re: CLUTCH LINE
disconnect the line from the slave cylinder and see its pushing fluid through to the slave. If there is no fluid being pushed that might be ur problem.
FYI lose the caps
Old Jan 14, 2011 | 05:11 AM
jdm kidd's Avatar
sorry bout the caps. but fluid shoots threw but the pedal wont even come back up if i open the slave cylinder it will push fluid but it wont create pressure to come back up
Old Jan 14, 2011 | 05:48 AM
crazes's Avatar
Moderator
make sure that ur slave cylinder is not leaking fluid throught the bleeder part. Just take some teflon tape and place put it on the bleed screw just to be sure its good
also did you bench bleed the master before you started everything else?
Old Jan 14, 2011 | 06:35 AM
luck4rmkc's Avatar
The chase bays kit uses a -3AN line. It is also normal for the clutch pedal to stick to the floor when bleeding. Everytime you push it down you will have to reach down and lift it back up with your hand. This is kind of PITA but it's just part of it. Every clutch system I have ever bled the pedal sticks to the floor. Try letting it gravity bleed for a a bit then go back to regular bleeding.
Have you actually closed the bleeder and felt the pedal yet? or are you assuming since the pedal goes to the floor with the bleeder open that there must be something wrong?
Old Jan 14, 2011 | 07:02 AM
redboost10's Avatar
With these aftermarket slaves we have always had to take the line off at the slave, cover the whole with our finger and pump the pedal to get it to prime, reattach the line and continue bleeding.
Old Jan 14, 2011 | 07:14 AM
q16racer's Avatar
Use -3. iI had this same problem after getting a clutch line kit from king that was -4. I sent it back, got a refund and had one made for me at carquest in -3. Worked flawlessly after that.
Old Jan 14, 2011 | 08:09 AM
MrParks's Avatar
you should have no problem with a -4. pressure is pressure. and i dont think .025 larger hose is gonna kill u.
prime both master and slave if there new. then do a normal bleed procedure, should work fine.
Old Jan 14, 2011 | 08:21 AM
jdm kidd's Avatar
THANKS GUYS IM GONNA TRY LETTING IT GRAVITY BLEED THEN TRY DIS CONNECTING FROM SLAVE AND DOING THAT
ALSO THE PEDAL DONT COME OUT AT ALL CUZ THERE IS NO PRESSRE CUZ THE SLAVE CYLINDER IS NOT ENGAGING
Old Jan 14, 2011 | 09:33 AM
I.C.C.'s Avatar
I had the same problem but with a brand new master, new slave, and new clutch line... No matter what I did, I just couldnt seem to get it to feel right... Used a vacuum pump bleeder, and now it feels great...
Old Jan 14, 2011 | 01:53 PM
IN VTEC's Avatar
Pressure is dependent on the volume displaced.
Old Jan 14, 2011 | 04:03 PM
jdm kidd's Avatar
WELL I TRIED THE GRAVITY THING BUT FORGOT ABOUT IT AND IT ALL BLED OUT SO GONNA TRY AGAIN IN THE MORNING
WHEN I GRAVITY BLEED SHOULD PEDAL BE UP OR DOWN
Old Jan 14, 2011 | 04:10 PM
Stealthmode Performance's Avatar
Why you yellin, yo? lol
Old Jan 15, 2011 | 06:07 AM
luck4rmkc's Avatar
Just leave the pedal up when you gravity bleed. But now that you ran the CMC dry you may want to re bench bleed the CMC as someone suggested above ^ when they talked about putting your finger over the port while pumping with the line loose...
chris89
Transmission & Drivetrain
Nov 14, 2014 06:53 PM
jdm kidd
Jan 14, 2011 08:22 AM
sideswiped
Jun 13, 2010 01:35 PM
rhdins
Nov 3, 2009 03:22 AM
