Car breaking up in Boost.
Old Aug 17, 2014 | 10:54 AM
LiLJisBooSTin89's Avatar
Default Car breaking up in Boost.
Sup guys, just got my LSV-T hatch back on the road went and got it tuned 2 weeks ago on 12psi put down right at 300hp to break it in. Well cars been running great. I went out to play in it Friday night and now the car runs fine except when I get to 8psi+ of boost the car starts breaking up bad. ive checked plugs(they were nasty so I changed them didn't change the way the car felt at all) vacuum lines ect ect went over the basics. any ideas will be appreciated setup on the car is:
LS block
css
cp 9:1
eagles
supertech vavletrain in b16 head
go autoworks turbo kit
Neptune
880s
hks evcs
Old Aug 17, 2014 | 10:59 AM
welfarepc's Avatar
Default Re: Car breaking up in Boost.
What was your spark plug gap on the old plugs?
Chances are you didnt gap your plugs right, and the gap is too large for the spark to jump in boost.
The denser the air inside the combustion chamber, the more molecules are in the way of the electricity trying to jump the air gap at the spark plug tip. How can you make it easier for the spark to make the jump? Make the jump smaller.
So pull the plugs, gap them down a bit. Chances are they are at .044" if they are -11 plugs or .032" if they are standard gap plugs. Gap down to ohh lets say .025" and test, and see how it goes. Still getting ignition issues? Try .020".
Good luck.
Old Aug 17, 2014 | 12:45 PM
the old plugs were .25 and gapped all these to .25 even pulled them out and rechecked just to make sure. u think I should try goin to .2? it really feel like ignition
Old Aug 17, 2014 | 12:55 PM
F22Master's Avatar
Check you cap, rotor, and plug wires. I bet its one of those three things.
Old Aug 17, 2014 | 01:08 PM
boosted94gsr's Avatar
On my old turbo gsr setup I had the same problem. I replaced the cap and rotor with new OEM parts and it fixed all my issues. If you ignition system is stock make sure you only use OEM components. Parts store ignition stuff is junk.
Old Aug 17, 2014 | 05:45 PM
DDTECH's Avatar
Blowing spark out. Video would help, return to tuner and let him diag it with you. You're only going to get so much help on a forum without more info.
Old Aug 18, 2014 | 07:43 AM
Lost compression on cylinder #2 jus got it apart cracked ringlands after 700 miles thanks for the help guys
Old Aug 18, 2014 | 08:11 AM
Damn! Sorry to hear that man. Good luck with the rebuild. Come back stronger and faster.
Old Aug 18, 2014 | 10:56 AM
Dark_Teg's Avatar
You cracked the ring lands on the CP's?
Old Aug 18, 2014 | 05:14 PM
king06's Avatar
X2 only seen on stock pistons.
Something must be really wrong.
Old Aug 18, 2014 | 07:16 PM
efHondefender's Avatar
how on earth could you crack ring lands on forged pistons at 300whp?
Old Aug 18, 2014 | 08:48 PM
On my first ever turbo setup I cracked a sleeve wide open at only 330whp do to a shitty *** tuner running a stock map sensor at 12+lbs of boost. Op you need to figure out what when wrong to cause that kind of damage at such a low power level.
Old Aug 19, 2014 | 12:17 AM
J.Berta's Avatar
I had crappy plug wires get me before with misfiring with higher boost levels. 7 lbs would be fine and never break up, but once I increased beyond that it would misfire. Something easy to check and fix. This also happened after I got my car tuned as well. Hopefully this is will help!
Old Aug 19, 2014 | 01:53 PM
Bent Rod was cause of pistion cracking I got so caught up n the.ringlamds.beimg.cracked.I failed.to realize.the.rod.was smashed and.bent.like.it.had.hit.something I bought the motor assembled.from a.guy with all kinda people.vouching.for.his.work lesson learned tho if.its.to good.of.a.deal it.usually.is
Old Aug 19, 2014 | 02:22 PM
Took me 10 mins to read that with all the periods lol.
That sucks man I learned that lesson the hard way too. I don't trust what anyone says, I check it all over myself.
Old Aug 22, 2014 | 06:47 AM
2000CTRSi's Avatar
Post a pic of the damaged cp piston bro. I wanna see it if you can
Old Aug 22, 2014 | 07:15 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Sorry to hear....I would like to see pics as well of it all
ej1252
Oct 26, 2007 06:05 AM
ef dino
Oct 22, 2007 04:46 PM
i dunno
Honda S2000
Oct 13, 2006 01:02 PM
kaoss_11
Mar 12, 2005 07:03 PM
u_tal
Nov 10, 2004 03:01 PM
