Calling you guys making 700whp+, What head work is needed on a GSR head?
Old 07-29-2011, 12:24 AM
dantamparacer's Avatar
Default Calling you guys making 700whp+, What head work is needed on a GSR head?
I have the bottom end planned out already, but I am kinda confused on all I need to replace in my GSR head. I have already done the springs, retainers and valves. But my machine shop is telling me I need to drop all this money on all these various parts, which i cant remember, that are not broken or wore out, I am not really sure if I trust him he is an old big block chevy guy. Any help
Old 07-29-2011, 12:44 AM
Boosted_B_Series's Avatar
Default Re: Calling you guys making 700whp+, What head work is needed on a GSR head?
Maybe valve guides and valve seals is what he's trying to get you to replace? Its always a good idea to freshen up what you can afford while your in there. I would think valve seals would be easy and cheap while your there. Valve guides may be optional.
Lots of guys have been 700+ on stock gsr heads with just springs and retainers.
Old 07-29-2011, 01:42 AM
he checked and replaced the guides as needed when he replaced the rest of the parts and also replaced all of the valve seals. So all I "should" need is a good port job and call the head good?
Old 07-29-2011, 01:57 AM
a1320honda's Avatar
I made over 700whp on a completely stock ported GSR head on 24lbs. It had Brain Crower springs and retainers and stock valves and Skunk2 pro1 cams.
Old 07-29-2011, 02:39 AM
TURBOINTEGRA750's Avatar
i did it with stock ports and stock cams.
Old 07-29-2011, 04:55 AM
What turbo? What brand dyno?
Old 07-29-2011, 08:48 AM
jdm knight's Avatar
I've made over 750whp on a completely stock gsr head! Just spring & retainer and Pro 1 cams! And also know alot of people making over 700hp with just spring & retainers and type r cams!
Old 07-29-2011, 06:03 PM
KStuned's Avatar
The port doesn't need any work. It's a function of the cams and the turbocharger assuming a decent intake/exhaust manifold.
Supertech/Ferrea/Skunk valvesprings/retainers and any valves with a sealed up valve job (CHECK each valve seat, don't assume) and guides that aren't worn the f*** out and you should have no problem.
Old 07-29-2011, 09:47 PM
tagperformance's Avatar
Jus make sure if you do get your head ported get it done by a machine shop that specialize on honda heads like cnc, rlz, head games, etc
Old 07-30-2011, 01:54 AM
thanks for all the advice guys
Old 07-30-2011, 04:28 PM
CO_RaceFab's Avatar
I make 800+ on stock gsr cam stock head with springs and retainers
Old 07-31-2011, 12:17 AM
Are you talking about the PFC hatch? I am stationed in the springs but am currently deployed. When I get back is when the motor is going in and getting tuned. Who does the tune on your car? I was thinking about trying to get Sam at importsports to do mine. Any suggestions?
Old 07-31-2011, 02:40 AM
CO_RaceFab's Avatar
I tune my own car.... pfc are close friends of mine... sam is a great tuner I'm in greeley at co race fab I tune at pfi pm me if you need any help.
Old 07-31-2011, 01:09 PM
boosted91crx's Avatar
how much is safe on a completely stock head? using stock springs and all?
Old 07-31-2011, 01:18 PM
jdm inc's Avatar
i made 765 on stock ported head and rev valve springs and retainers and pro 1 cams
Old 07-31-2011, 05:14 PM
KStuned's Avatar
Stock gsr cams don't hold tq at high rpm. The ticket to power in a gsr head is a simple equation of Skunk2 Pro 1's, good valvesprings and a good valve job
Old 07-31-2011, 05:55 PM
reaction360's Avatar
I made 858whp @42psi on a stock port head/cams with aftermarket springs n retainers. I run it at 48psi at the track. I think with a good cam like a pro1, I could make more power at less boost with a better power band.
It's already been confirmed that you make plenty of power with a stock head. I wouldn't run stock springs n retainers on any car making 700+, if you're making that much power, you're obviously beating on it hard at the track and you just run the risk of engine failure.
Also, if money is tight, spend it on a good valve job vs. a port job.
Old 07-31-2011, 07:31 PM
3minburnout's Avatar
Also reaction360 didn't you make it with stock valves too?
Old 07-31-2011, 07:35 PM
CO_RaceFab's Avatar
I'm basically doing the same thing... it takes a gang of boost to make decent power it take me 52psi (s372) to go 155mph @ 6100ft
Old 07-31-2011, 09:17 PM
I ran the stock valves at that power for almost 3years and just recently switched to full ferrea valve train. I would've still been running them if I hadn't finally bent a few haha.
Old 07-31-2011, 09:45 PM
CO_RaceFab's Avatar
Did you change cams too? We are looking into some web cams
Old 08-01-2011, 05:21 AM
How they finally bend? Mis shift, over rev?
Old 08-01-2011, 03:22 PM
meane30's Avatar
We made 743 uncorrected in Denver, stock port head with ctr cams, springs and retainers. Just replace what needs to be replaced. Don't get crazy
Old 08-01-2011, 09:18 PM
thanks, that is around the power level I want to be at. I currently have the gsr cams and was planning on going to the skunk2 pro1's. Would the ctr's be a better choice? It is gonna be a sleeved 2l lsvtec built by erl any comments on the choice of bottom ends or does it sound ok?
Old 08-01-2011, 09:31 PM
I'm still on stock gsr cams. I decided to go upgrade the valvetrain this year so either cams or suspension next season.
Quick Reply: Calling you guys making 700whp+, What head work is needed on a GSR head?
