Cable trans help
Old Nov 13, 2011 | 07:36 PM
  #26
92frostwhtdb2's Avatar
Default Re: Cable trans help
Just run a hydro trans with mount and a kit from hush performance https://honda-tech.com/forums/acura-integra-6/da-hydro-conversion-hush-performance-2829894/
Old Nov 14, 2011 | 03:56 AM
  #27
Kevin's Avatar
Originally Posted by 89efhatchy
That's good to know, but I'm wanting an electronic vss for boost control purposes. Instead of just controlling boost by gear, you can also control it by speed so I'd like that option just in case it's needed to get the power down.
The cluster outputs a speed signal to the ecu in cable tranny cars.
Old Nov 14, 2011 | 05:07 AM
  #28
slowboy90's Avatar
jon comp also makes a release bearing like the tilton as well
Old Nov 14, 2011 | 07:38 AM
  #29
hush22's Avatar
Many racers have gotten away with using the cable Trans and depending on how much racing he does will determine what is best for the OP.
If the cable its self becomes a problem we can convert your cable transmission to hydraulic.
Depending on what type of clutch you will using will determine what type of hydraulic system will be best for you.
Old Nov 14, 2011 | 07:50 AM
  #30
89efhatchy's Avatar
Oh cool. I have friends who have used the tilton and also a friend thats a Tilton dealer so itll work out the best for me.
hwt101
Dec 2, 2008 10:46 PM
sikciv666
Jan 31, 2006 12:32 PM
rice a roni
Dec 6, 2003 04:12 PM
