boost problem...
i am having a big problem with my boost. it wont go any lower than 23psi with a 14psi spring and it wont boost any higher than 27 with the boost controller wide open?
its a tial Q and its the precision 4062 with the h cover. im pretty sure the wastegate placement is the problem with the low boost problem but i cant figure out why it wont boost over 27psi. i ck for boost leaks. found none. i was wandering tho, i have pro2's and there set to 0. is it possible to have to much overlap and its just pushing all the boost out the exhaust and thats both my problems?
oh and i have the turbo xs 4 stage boost controller. i am putting a mac solenoid on it tomorrow before i go back to the dyno.
Low boost problem - wastegate size, placement, spring, or too big of turbine wheel
High boost problem - high eMAP blowing the gate open, solenoid hooked up wrong, or boost leak
My money is on the solenoid being hooked up wrong. How is the boost solenoid setup? Make sure to clamp the wastegate instead of bleeding the source.
i have seen on several cars that they are running dual boost soleniods. anybody with more info on just how exactly they work feel free to chime in! i do no that it lets you be able to run low boost levels out the hole and still be able to run 45-55psi without co2
i no how the solenoid hooks up. i got one on my street car. i dont no how to set up the duel solenoid? and i dont even no if my aem will run the second solenoid
He wants to use 2 to build more pressure.
When I get home I'll report back with how my car is set up using two solenoids.
Do you have an EMS can can control both seperatly? V1 or V2 AEM?
the boost controller at the moment is a line off the compresser to the inlet of the first stage of the controller and the other side goes to the bottom of the wastegate just like the directions say. but i am getting rid of it cause i dont like it. i have 2 mac soliniods but i dont no if the v1 aem will run 2 solinoids? and i nor my tuner no's how to set it up to do so
Also, you don't always need two solenoids to run high boost. Just start with one that clamps the top shut. If that's still not enough boost for you, use the second solenoid to bleed the bottom port while the other one clamps the top. Chances are you won't need a second solenoid. Hope that helps.
quick help please. i got it down to 16psi with redoing the wastegate placement and the dump tube. but i still cant get but 27psi out of it with a single mac solenoid. does anybody have a diagram on how to hook up a second boost solenoid? my ems with run it i just need to no how to hook up the lines and were to wire the second solenoid to. thanks!
