boost problem...
Old May 23, 2011 | 09:40 AM
061000rr's Avatar
Default boost problem...
i am having a big problem with my boost. it wont go any lower than 23psi with a 14psi spring and it wont boost any higher than 27 with the boost controller wide open?
Old May 23, 2011 | 09:54 AM
theidealone's Avatar
Default Re: boost problem...
Sounds like an issue I just had. Are you running a solenoid? I had my lines hooked up backwards. So it was just constantly leaking out of the vent.
Old May 23, 2011 | 10:05 AM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
do you have a bov and a anti surge housing?
Old May 23, 2011 | 10:26 AM
061000rr's Avatar
its a tial Q and its the precision 4062 with the h cover. im pretty sure the wastegate placement is the problem with the low boost problem but i cant figure out why it wont boost over 27psi. i ck for boost leaks. found none. i was wandering tho, i have pro2's and there set to 0. is it possible to have to much overlap and its just pushing all the boost out the exhaust and thats both my problems?
oh and i have the turbo xs 4 stage boost controller. i am putting a mac solenoid on it tomorrow before i go back to the dyno.
Old May 23, 2011 | 10:39 AM
UJLSMoFo's Avatar
i had the same issues. wastegate spring duty was like at 300% couldnt stay closed and the bov was leaking.
Old May 23, 2011 | 10:43 AM
Garage 808 Hatch's Avatar
take the wastegate spring out, and see what it does, then report back
Old May 23, 2011 | 08:13 PM
Divers's Avatar
Low boost problem - wastegate size, placement, spring, or too big of turbine wheel
High boost problem - high eMAP blowing the gate open, solenoid hooked up wrong, or boost leak
My money is on the solenoid being hooked up wrong. How is the boost solenoid setup? Make sure to clamp the wastegate instead of bleeding the source.
Old May 24, 2011 | 04:36 AM
061000rr's Avatar
the boost controller at the moment is a line off the compresser to the inlet of the first stage of the controller and the other side goes to the bottom of the wastegate just like the directions say. but i am getting rid of it cause i dont like it. i have 2 mac soliniods but i dont no if the v1 aem will run 2 solinoids? and i nor my tuner no's how to set it up to do so
Old May 24, 2011 | 08:07 AM
Why would you need 2 solenoids?
Old May 24, 2011 | 09:16 AM
061000rr's Avatar
i have seen on several cars that they are running dual boost soleniods. anybody with more info on just how exactly they work feel free to chime in! i do no that it lets you be able to run low boost levels out the hole and still be able to run 45-55psi without co2
Old May 24, 2011 | 11:20 AM
UJLSMoFo's Avatar
port 2 of the solenoid should go to the top of wastegate, port 1 should be tee'd from compresser and bottom of wastegate.
Old May 24, 2011 | 11:31 AM
061000rr's Avatar
i no how the solenoid hooks up. i got one on my street car. i dont no how to set up the duel solenoid? and i dont even no if my aem will run the second solenoid
Old May 25, 2011 | 09:24 AM
UJLSMoFo's Avatar
yes it can but there are a lot variablies. should work fine with just one soleniod.
Old May 25, 2011 | 10:15 AM
tepid1's Avatar
He wants to use 2 to build more pressure.
When I get home I'll report back with how my car is set up using two solenoids.
Do you have an EMS can can control both seperatly? V1 or V2 AEM?
Old May 25, 2011 | 11:44 AM
061000rr's Avatar
i have the newest v1 i belive? its the darker grey box.
Old May 25, 2011 | 01:04 PM
Divers's Avatar
That's a bleed style setup, which would explain why you are having trouble make high boost. Once the emap gets high enough it overcomes the wastegate spring and blows the valve open. You need to clamp the top.
Also, you don't always need two solenoids to run high boost. Just start with one that clamps the top shut. If that's still not enough boost for you, use the second solenoid to bleed the bottom port while the other one clamps the top. Chances are you won't need a second solenoid. Hope that helps.
Old May 30, 2011 | 05:57 AM
061000rr's Avatar
quick help please. i got it down to 16psi with redoing the wastegate placement and the dump tube. but i still cant get but 27psi out of it with a single mac solenoid. does anybody have a diagram on how to hook up a second boost solenoid? my ems with run it i just need to no how to hook up the lines and were to wire the second solenoid to. thanks!
Old May 30, 2011 | 03:40 PM
Divers's Avatar
Something else is wrong. What are you currently using and how is it setup?
Old May 30, 2011 | 03:45 PM
Divers's Avatar
Just read this. Try moving your centerlines apart. Not saying its your problem, but see what happens.
Old May 30, 2011 | 06:07 PM
UJLSMoFo's Avatar
lose the bov and put in a 18 to 20psi wg spring.
Old May 31, 2011 | 09:15 AM
061000rr's Avatar
would you say start at 1 degree each way or go more than that and then move back to center 1 degree at a time?
Old May 31, 2011 | 01:12 PM
Divers's Avatar
110/110 is a good starting point, but I still think its a boost control problem(solenoid, lines, sources, etc.).
Old May 31, 2011 | 03:04 PM
UJLSMoFo's Avatar
im running the pro2's they are advanced 2 and 2, no bov, one mac soleniod and a 18psi wg springs, im makin 52psi no problem.
Old May 31, 2011 | 08:21 PM
Divers's Avatar
I don't know about the "no BOV" part, but I would say this confirms that you have a soleniod issue or something hooked up wrong.
Old Jun 1, 2011 | 08:36 AM
UJLSMoFo's Avatar
are you running two wastegates?
