Big boost?
Old Jan 15, 2007 | 03:36 PM
5thgearburnout's Avatar
Default Big boost?
Just wondering what people running high boost (45lbs+) are using for head studs, will the standard size arp work or should i have my machine shop drill and retap for the bigger half inch studs. I have also heard about a new stronger material L98 i think. This is on a 84 mm b series. The block is sleeved with golden eagle hd sleeves and oringed. Experienced comments please. Thanks in advance.
Old Jan 15, 2007 | 03:45 PM
FMUNK's Avatar
Default Re: Big boost? (5thgearburnout)
I see NO reason to use anything other than stock size.
We use the Golden eagle headstuds.
Never had trouble with ARP's either, But I like the GE MUCH better!
Old Jan 15, 2007 | 03:48 PM
Thanks alot you guys would know.
DaveF's Avatar
Default Re: Big boost? (FMUNK)
we arent pushing over 45psi(yet) .... but we do run stock size studs (GE block/o-rings) with no problems.
Old Jan 15, 2007 | 05:13 PM
civic eg's Avatar
hey fmunk, are u guys running stock size head studs on eggums car?
Old Jan 15, 2007 | 05:18 PM
ek9t72's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FMUNK &raquo;</TD></TR><TR><TD CLASS="quote">I see NO reason to use anything other than stock size.
Never had trouble with ARP's either, But I like the GE MUCH better!</TD></TR></TABLE>what head gasket are u using in that monster
avotegra
Apr 20, 2008 11:50 AM
B18EG6
Jan 15, 2007 07:21 AM
o'malley_808
Aug 31, 2006 10:05 AM
fastludeh22
May 20, 2004 10:34 AM
boostedcvc
Jan 2, 2004 06:21 AM
