b20 block with a b16 head...
Old Jan 7, 2004 | 03:23 PM
slowsupra's Avatar
Default b20 block with a b16 head...
this combo with 11-1 compression in a 96 civic hatch, about how fast do you think it would be in the quarter? jay
Old Jan 7, 2004 | 06:06 PM
M.A.R.C.'s Avatar
Default Re: b20 block with a b16 head... (jaynite1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaynite1 &raquo;</TD></TR><TR><TD CLASS="quote">this combo with 11-1 compression in a 96 civic hatch, about how fast do you think it would be in the quarter? jay</TD></TR></TABLE>
gotta be a lil bit more specific with your setup. i'm guessing you mean with bolt ons? full interior? cams?
8200RPM's Avatar
local hippie
so... sounds like a nice setup so far...
what other mods? bolt ons? clutch, flywheel, what kind of wheels/tires, gutted hatch? etc... i think with those details someone could give you a better idea.
Old Jan 8, 2004 | 07:20 AM
slowsupra's Avatar
Default Re: b20 block with a b16 head... (CivicRyda2k)
bolt ons and a full interior.. I'm trying to get an idea on how fast my friends car might be.. it does have a upgrade clutch also.. probably some hondata tuning when everythings done..jay
Modified by jaynite1 at 2:37 PM 1/8/2004
Old Jan 8, 2004 | 10:58 AM
MikeMAN's Avatar
since I can't really help with such a vauge question...
here is my contribution:
1998 EX Coupe FULL INTERIOR
Street Tires (Bald 15" Mushimoto ZX..not sure what kind)
bone stock b16a2 head
bone stock b20b bottom end (low compression)
b16a2 tranny
14.8 @ 95mph
hope that helps,
mike
p.s. the head + block combo above is a 9.5+/- compression setup, VERY VERY low for all motor
Old Jan 8, 2004 | 01:21 PM
see_our_vtec's Avatar
Default Re: b20 block with a b16 head... (MikeMAN)
b20b4 block with b16 head is 9.09:1 compression*
Old Jan 8, 2004 | 02:51 PM
roots01's Avatar
I'm running a bone stock CR-vtec motor with an AEM-V2 and a V-AFC. I don't know my 1/4 time but my first dyno run put down 167.8 hp and 137.7 tq. This is in a 99 Si.
Old Jan 8, 2004 | 08:46 PM
smokey2.0's Avatar
Default Re: b20 block with a b16 head... (roots01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roots01 &raquo;</TD></TR><TR><TD CLASS="quote">I'm running a bone stock CR-vtec motor with an AEM-V2 and a V-AFC. I don't know my 1/4 time but my first dyno run put down 167.8 hp and 137.7 tq. This is in a 99 Si.</TD></TR></TABLE>
not bad!
Old Jan 10, 2004 | 05:13 AM
roots01's Avatar
Default Re: b20 block with a b16 head... (smokey2.0)
Thanks. It's going turbo soon.
Old Jan 10, 2004 | 05:19 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roots01 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. It's going turbo soon.</TD></TR></TABLE>
becareful with the stock b20 sleeves... they're known to be a lil on the weak side. a friend of mine had one with rods and pistons and it cracked a sleeve @ 10psi.
Old Jan 10, 2004 | 05:28 AM
roots01's Avatar
I'm going to run it at 5 psi for now with a hondata. I'm not going to go all out with it until I can build the bottom.
Old Jan 10, 2004 | 09:41 AM
MikeMAN's Avatar
Default Re: b20 block with a b16 head... (see_our_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by see_our_vtec &raquo;</TD></TR><TR><TD CLASS="quote">b20b4 block with b16 head is 9.09:1 compression*</TD></TR></TABLE>
wrong, 9.28:1
Old Jan 10, 2004 | 09:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
wrong, 9.28:1
might wanna double check your math
if you wanna get technical. it is......9.095499790225623:1
Old Jan 10, 2004 | 08:39 PM
MikeMAN's Avatar
you might wanna check your methods of calculations...
once again...it IS 9.28:1
mike
Old Jan 11, 2004 | 12:25 AM
mike</TD></TR></TABLE>
go to http://www.cspeedracing.com
b16 head, b20 block, usdm b20(p3f) pistons, oem head gasket, b20 piston to deck height.
~9.09
research it before you give false answers.
-brian
Old Jan 11, 2004 | 06:00 AM
Se-rv-Tak's Avatar
the result of the b20b4 stock bottom end, and the b16 head... is 9.0:1
Old Jan 11, 2004 | 06:04 AM
Default Re: b20 block with a b16 head... (Se-rv-Tak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Se-rv-Tak &raquo;</TD></TR><TR><TD CLASS="quote">the result of the b20b4 stock bottom end, and the b16 head... is 9.0:1</TD></TR></TABLE>
someone else who knows how to calculate correctly and give correct answers.
Old Jan 11, 2004 | 09:09 AM
MikeMAN's Avatar
i knew i forgot a checkbox somewhere..
mike
Old Jan 11, 2004 | 09:12 AM
it's all good, if you check my sig, you'll see i'm building one, and i've had to dig through a lot of true and false statements, so it kinda gets irritating sometimes.
Old Jan 11, 2004 | 12:22 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by see_our_vtec &raquo;</TD></TR><TR><TD CLASS="quote">it's all good, if you check my sig, you'll see i'm building one, and i've had to dig through a lot of true and false statements, so it kinda gets irritating sometimes.</TD></TR></TABLE>
yup, i did the same thing last year...tons of rumors out there too..but, enjoy the motor..i know i loved mine while i had it
mike
stratedrm
Aug 8, 2007 09:31 AM
MD06LBP
Sep 22, 2006 03:17 PM
Grip
Jun 1, 2005 06:51 PM
kaoss_11
Jun 4, 2004 03:01 PM
HaTcHBoY94
Jun 24, 2003 03:47 PM
