B16 Gearing Question..
Old Jan 17, 2007 | 03:21 PM
Zeusfire69's Avatar
Default B16 Gearing Question..
Does anyone know how fast a stock B16 tansmission will let the car go in 4th gear at 8900 rpms on 22" slicks. I'm just trying to make sure that I don't need bigger slicks to het into the 10's. Obviously, shifting into 5th isn't going to work...
Old Jan 17, 2007 | 04:36 PM
Private-Tune's Avatar
Default Re: B16 Gearing Question.. (Zeusfire69)
edit.... see below
Modified by Private-Tune at 1:15 PM 1/18/2007
Old Jan 17, 2007 | 05:40 PM
Zeusfire69's Avatar
Default Re: B16 Gearing Question.. (Private-Tune)
OK, that's all I had to hear. Thanks!
Old Jan 17, 2007 | 05:48 PM
WillieWillieFast's Avatar
Check out this page. It should help you out.
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
Old Jan 17, 2007 | 06:03 PM
Zeusfire69's Avatar
Default Re: B16 Gearing Question.. (WillieWillieFast)
KICK *** link, thanks! I use this **** out of that!!
From using that calculator, it looks like I'm going to be needing some 24.5", or at least some 23"....am I right?
Old Jan 17, 2007 | 07:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeusfire69 &raquo;</TD></TR><TR><TD CLASS="quote">KICK *** link, thanks! I use this **** out of that!!
From using that calculator, it looks like I'm going to be needing some 24.5", or at least some 23"....am I right?</TD></TR></TABLE>
Or rev your engine higher. I dont recomnend it, if its on a stock head.
Old Jan 17, 2007 | 08:49 PM
Rage Cayman's Avatar
I have a program that can tell you how fast a b16 tranny or any tranny will get you. First you have to know all the gear ratios and what tire size ETC alot of variables in this formula i have.
Old Jan 18, 2007 | 01:58 PM
Gearspeed-Performance's Avatar
Default Re: B16 Gearing Question.. (Rage Cayman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rage Cayman &raquo;</TD></TR><TR><TD CLASS="quote">I have a program that can tell you how fast a b16 tranny or any tranny will get you. First you have to know all the gear ratios and what tire size ETC alot of variables in this formula i have. </TD></TR></TABLE>
Kirk is a baller with all these programs
Old Jan 18, 2007 | 04:15 PM
Zeusfire69's Avatar
Default Re: B16 Gearing Question.. (GearSpeedEF7)
I do plan on putting good springs and retainers in the head, but that's it....how high do your think I can rev with just that...Am I pushing my luck at 9500?
Old Jan 18, 2007 | 07:12 PM
fast is fun's Avatar
http://www.f-body.org/gears/
drag racing not autocross
dispropimphoez
Transmission & Drivetrain
Feb 27, 2010 02:04 PM
CVCGUY
Feb 5, 2006 12:24 AM
the.hamburglar
Aug 17, 2005 04:20 AM
coot_er
Jun 29, 2005 02:14 AM
