B series with K series axles and K series cv joints?
Moderator
This is pretty much a copy of another thread. I have a few that would like more information about this so i figured put it in here and see if there is some more info over here for them
Ok I know I've read it somewhere on Honda-tech that people been running there b series swapped cars with k series Axle's to be able to have the stronger 36mm outer cv joint... For the life of me I can not find any more info on what has to be done to do this, which axles are used and what mod's have to he done to do so ... So if anyone has any info on it is like to know
And if anyone is having good luck with this set up Thank!
Some actual part numbers would be great also
Re: B series with K series axles and K series cv joints?
almost 100% sure K series inners fit in b series trans no need to swapp inners
just need the karcepts hubs
i ran 90-91 prelude si hubs. you use the inner race's of the prelude wheel bearing and the rest of the integra bearing. you can then run accord outters with the big shaft b series inner's and shafts. and you can keep 4x100 4 lug wheels.
I'm using stock 06 civic si axles in a b series eg no modification to axles. Just karcepts hubs.
Sweet. So other question if u do the 90-91 prelude hubs u have to get both sets of wheel bearings do make one set work?
I got mine used with tho hole spindle. And just used my old integra bearings and the inner race's that were on the hubs. There is a used Honda parts place on eBay that has several sets of spindles. They have the stock axles also. You may be able to run the prelude axles and not have to make your own.
Just a heads up for those doing this, the oem Honda/Acura axles use larger shafts and stronger cv's then the autoparts store brands. Basiclly the oem ones are stronger.
I know this is off topic but simular so I'll ask, is there oem hubs you can use with the dss 5.9 axles?
No, Im pretty sure they're the same outer as a GM 4wd truck. The outers on my 5.9's and the front axles of my truck look identical
Wanting to know more info for my DA Integra, I need to put extended studs in it and would like to look into this alternative for now.
Moderator
its basically the same thread. there was no real information on there. Had a few people ask to me post in here for more knowledge
