Axle Help!!!!!
Old May 6, 2009 | 11:16 PM
b20vcrxsir's Avatar
Default Axle Help!!!!!
Hi I have a 1995 Acura Integra.
The setup is:
B20 block (All Stock)
B16 Head
GSR Cams
Blox Manifold
4-2-1 Headers
2.5" exhaust (no cat)
75 wet shot (single fogger)
150whp(motor)
256whp(bottle)
The problem is I went to the track this weekend and I used some BFG drag radials(18psi). I was launching at 6000RPM without using the nitrous and two times my driver side axle (pepboys axles) snapped at the spindel.
I want to know what can be causing this?
(could it be cheap axles, not launching high enough, psi in tires, dumping the clutch, ect)
Old May 7, 2009 | 01:30 AM
1992Si's Avatar
Default Re: Axle Help!!!!!
Not pre-loading the driveline, and dumping the clutch.
As well as using those cheap axles. You'll here lot's of stories about how some guy's do fine with cheap axles. In a DD I've gone through 4 of them before I found a good one. Free life time replacement, yea, you do the labor 4 times.
Search, there are a ton of axle threads.
Hesperia, I used to live there, I was at GAFB in the late 70's.
Old May 7, 2009 | 05:33 AM
BlakeJ53's Avatar
Thats your problem right there you should have gone with AUTOZONE AXLES.... AHAHA JK PreeeeeLoad
Old May 7, 2009 | 11:12 AM
Ls_dx's Avatar
Oem honda axles seem to be pretty hogh quality... see if you can get your hands on some of those... and preloading is a good idea ... although I never did last year, I just domped the clutch at 8grand on slicks 170 60 ft... with a heavier car... maybe they are just crap axles that you have..?
Old May 7, 2009 | 05:32 PM
Gonzob16's Avatar
What do you mean by preloading?
Old May 9, 2009 | 12:50 PM
J.Berta's Avatar
its like letting out on the clutch alittle so the the drivetrain is tight. instead of the drivetrain being loose. The sudden slap of the clutch and loose drivetrain is the problem tho.
Old May 9, 2009 | 01:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
preloading ahs been talked about alot.
basically it is this, let the clutch out enough to move the car but not enough that it cant be held with the ebrake.
Old May 10, 2009 | 06:20 AM
JayWest's Avatar
i think someone should make an in car video of the proper way to preload
that would answer a lot of the questions posted here
Old May 10, 2009 | 12:08 PM
Ls_dx's Avatar
practice makes perfect. It just takes some getting used to.
j13
May 4, 2016 08:30 PM
Dave_Dc2
Sep 23, 2009 11:34 AM
turboedsupe
Feb 9, 2009 11:43 AM
lowtegsr
Jan 10, 2008 03:45 PM
Snail EK
31
Nov 5, 2003 07:29 PM
